Cutting Stove Pipe... - HVAC - Contractor Talk
Old 01-11-2018, 04:49 PM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 4,366
Replacing the barrel stove stove pipe.
What is your preferred method/tool to get a nice, clean cut?
6" diameter.....24 gauge.
Thanks
Democrats are doing more to undermine our country than Russians could ever hope to.
Robie is online now
Old 01-11-2018, 04:55 PM   #2
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 190
Re: Cutting Stove Pipe...
The black pipe stuff?
Tin snips.
Measure, layout and cut before it gets snapped into the round shape.
jlhaslip is offline
Old 01-11-2018, 05:00 PM   #3
Robie's Avatar
Tin snips.
Yup...too late for that.
I've got snips, fine-tooth metal jigsaw blade, cut-off wheel for both grinder and die-grinder, hacksaws....
Robie is online now
Old 01-11-2018, 05:01 PM   #4
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,236
Chainsaw.
Really just like jlhaslip said work the best.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
Robie (01-11-2018)
Old 01-11-2018, 05:03 PM   #5
Robie's Avatar
Originally Posted by Randy Bush View Post
Chainsaw.
Cool. Should I brace it between my legs to hold it in place?
Robie is online now
Randy Bush (01-11-2018)
Old 01-11-2018, 05:04 PM   #6
Randy Bush's Avatar
Being you already snapped it together Can cut down the pipe with snips to your length then cut around.
Robie (01-11-2018)
Old 01-11-2018, 05:08 PM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,728
I don't know about 24 but 26 will often come apart if you press in on the seam at one end. Don't cut your fingers....
Inner10 is offline
Robie (01-11-2018)
Old 01-11-2018, 05:09 PM   #8
Railman's Avatar
Trade: Railing
Rewards Points: 459
Since it's in the round, I'd use a circular saw with abrasive blade.
Take a sheet of paper, or light card board, & tightly wrap around pipe with about 1/2 circumference lap or so. Mark at edge of paper.
When you go to cut, roll pipe towards you while cutting. Leave blade about 3/4" or so deep in cut. Much more, & you won't be able to guide it. Less & it will wander too much.
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
Robie (01-11-2018)
Old 01-11-2018, 05:46 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,657
Snips. I usually just wrap my tape measure around it to trace a line.
Tinstaafl is online now
Robie (01-11-2018)
Old 01-11-2018, 06:51 PM   #10
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,029
Just a hunch...rough cut outside your line (hacksaw, sawsall, etc,) , then clean it up with snips.
MarkJames is online now
Robie (01-11-2018)
Old 01-11-2018, 07:15 PM   #11
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,786
Telescoping pipe.
Golden view is online now
Old 01-11-2018, 07:17 PM   #12
Robie's Avatar
Originally Posted by Golden view View Post
Telescoping pipe.
The shortest length I could find was too tall when fully collapsed.
Robie is online now
Golden view (01-11-2018)
Old 01-11-2018, 07:18 PM   #13
Robie's Avatar
I like this idea.
Robie is online now
Old 01-11-2018, 07:33 PM   #14
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 4,702
I use my Milwaukee metal cutting circular saw to cut large diameter dust pipe all the time.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 01-11-2018, 07:51 PM   #15
Robie's Avatar
I don't have a Milwaukee metal cutting circular saw...
Robie is online now
Old 01-11-2018, 08:16 PM   #16
Inner10's Avatar
Treat it like spiral duct, cut it with a grinder and a zippy wheel.
Inner10 is offline
Old 01-11-2018, 08:35 PM   #17
Robie's Avatar
I ended up using the jigsaw on the 4" piece to be cut off as a test first. It cut like butter. I used a Bosch T123X Progressive Metal blade.
No vibration...followed the line beautifully and no burr to speak of. A little on the outside that emory cloth took care of in 30 seconds.
Thanks for the replies.
Robie is online now
Old 01-12-2018, 07:39 PM   #18
Renaissance Man
superseal's Avatar
Rewards Points: 5,598
I know your done and I'm chiming in late, but since I cut lots of smoke pipe in galvy and stainless...a 4 1/2" grinder with metabo "slicer" blades are my go to when the pipe is already assembled or in laser weld form.
Cleaning up any burrs, my weapon of choice is a diamond drum wheel on a dremel.
If your seams aren't locked yet, malco bulldogs or their metal shear drill attachment usually make quick work of it.
supersealconstruction.com
superseal is online now
The Following User Says Thank You to superseal For This Useful Post:
Robie (01-12-2018)
Old 01-12-2018, 08:02 PM   #19
ofmanyone's Avatar
Trade: carpenter
Rewards Points: 40
Due to the haphazard nature of using the wrong snips for the application. Consider cutting -1" long and then resnip to accurate length. That sliver of pipe is much easier to manage than 8" hanging off the waste side of the cut.
Sent from my XT1650 using Tapatalk
ofmanyone is offline
The Following User Says Thank You to ofmanyone For This Useful Post:
Robie (01-12-2018)
Old 01-12-2018, 08:21 PM   #20
Railman's Avatar
Trade: Railing
Rewards Points: 459
Same here. We are on our 4th shop setup, from 2,000 ft to 17,500 ft. A lot of pipe cut.
But....
Abrasive blades are about $5 ea, where as carbide metal blades run about $40.
I've done a lot with both.
Railman is offline
What is this pipe? AmeliaP Plumbing 1 03-01-2013 06:45 PM
Chimney pipe help bsp General Discussion 8 10-23-2009 12:20 PM
Alcove for Wood Stove Agolk2 Construction 0 09-02-2008 12:23 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 11:47 AM
