Cracked Heat Exchanger
Old 02-10-2009, 02:57 PM   #1
SIDrywall's Avatar
Trade: Metal Framing, Sheetrocking, Taping
I have been seeing a black residue around the registers in my house. Does this mean that I have a cracked heat exchanger? Can it mean anything else?
SIDrywall is offline
Old 02-10-2009, 08:49 PM   #2
manager
greghvacguy's Avatar
Trade: heating cooling tech
Re: Cracked Heat Exchanger
Its hard to say you should get your HVAC GUY in to look at the furnace. If you burn candals it can be from that.
greghvacguy is offline
Old 02-10-2009, 09:35 PM   #3
General Contracting
LNG24's Avatar
Trade: Real Estate Broker, Property Manager
Funny, just two weeks ago I checked on one of our Managed Properties we just remodeled and saw the black soot around the registers. Sure enough, Cracked Heat Exchanger!
We had a new furnace installed within two days.
I went back a week later and found...OIL! Leaking out of the unit. House smelled horrible
Brand New Unit had a cracked pump. I personally think it was cracked during install.
Now we are all good
LNG24 is offline
Old 02-10-2009, 10:39 PM   #4
westernhvac's Avatar
Trade: HVAC Contractor
It could be black soot deposition. Fireplaces, candles, cooking... they are all burning carbon. When this floats around in the air it will collect on surfaces of different temperatures at different rates. I can't remember if it is attracted to warm or cold surfaces.
Then again... check the heat exchanger just to be safe.
westernhvac is offline
Old 02-11-2009, 10:20 AM   #5
flashheatingand's Avatar
Trade: H.v.a.c.
It could be some leaky duct work as well.
flashheatingand is offline
Old 02-11-2009, 09:17 PM   #6
A.D. Const's Avatar
Trade: A.D. Contracting & Remodeling LLC.
Well might be a long shot, but to be possitive. Dirty filters or ducts? He said black residue not soot. Then again it might be soot, if that the case then I'll agree with posts above.
A.D. Const is offline
Old 02-17-2009, 03:31 PM   #7
SIDrywall's Avatar
Thank you for the help. I appreciate the feedback!!
heat pump jdager HVAC 2 01-31-2009 04:17 PM
Flat plate heat exchanger genecarp Plumbing 2 11-24-2008 10:09 PM
Heat Exchanger Problem with Hayward Pool Heater jtc1062 Pool Construction & Enclosures 6 10-24-2007 10:33 PM
Heat Exchanger Problem with Hayward Pool Heater jtc1062 HVAC 2 10-22-2007 10:13 PM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 04:38 PM
