#21 |
Trade: Geothermal, HVAC
Re: Cost Of Geothermal Units
And with all systems unfortunately, those "10" with no payback have been improperly installed. More than half of my pathetic life is service calls on Geothermal systems that have not been installed correctly. If they are not sized correctly, installed or used correctly, then no, there is no payback. Like PalaceGEO mentioned, it is downright frightening how many "HVAC" contractors know little to zip about Geothermal systems, but yet are 'experts' on the payback of them.
#22 |
Trade: General contractor
I have bid on a few projects that had Geo thermal heat but have yet to do one.
My HVAC sub tells me it cost just as much as gas to run. He tells me when you read what savings you could realize it is comparing costs to electric. Is he BS ing me? |
#23 |
I'm not sure if "BS-ing" you is putting it correctly. I truly hope he does not believe what he is saying and telling you. This is a fine example of what I run into all the time. Once again a contractor knows little to nothing about Geothermal, but they bad mouth them. Perhaps he once had a bad experience with one. I'm not sure, but that statement could not be more false.
Your most efficient Modulating furnace right now is 98% AFUE. This is fantastic and it is about time. This typically meaning that out of $1.00 of fuel that is put into the furnace, theoretically, you are getting 98% percent of that energy out of it. Again, theoretically. With a Geothermal unit, most now have a COP of 5 or more. Meaning that for every 1 kW that is used in a Ground Source Geothermal unit, They retrieve around 5 kW of usable energy that is therefore put into your home. Palace has a much more interesting way of explaining this... Hope that helps... Last edited by ciws14; 11-15-2009 at 07:39 PM. Reason: Grammar |
#24 | |
Trade: HVAC
Re: Cost Of Geothermal UnitsQuote:
The other half, maybe not. There are many areas, with gas rates low enough. That a geo doesn't save much over gas annually. Yep. There are many that are installed with wells that aren't deep enough. or improper grouting. And others on under sized duct systems. But, for the cost of the wells. You can pay for a lot of gas to heat the house, and a lot of electric for the air to air A/C, or heat pump. |
#25 | |
#26 |
Trade: Geothermal Systems
Yes...unless the gas rates are way low and the electric rates are way high.
Dewayne Dean www.palacegeothermal.com We heat and cool with dirt. Why settle for 90% when you can have 400% |
#27 | |
beenthere....not trying to pick a fight, but would you care to tell how you became an expert on geo systems? My credentials are listed on every post I make. We know nothing about yours.
Dewayne Dean www.palacegeothermal.com We heat and cool with dirt. Why settle for 90% when you can have 400% Last edited by palacegeo; 11-15-2009 at 07:49 PM. Reason: grammar |
#28 |
Trade: HVAC
Re: Cost Of Geothermal Units |
#29 | |
Thanks |
#30 |
I need 3 more posts before I can post a link
#31 |
I need two more posts before I can post a link
#32 |
I need one more post before I can post a link
#33 |
#34 |
here is another one Popular Mechanics
#35 |
You can always go here Palace Geothermal .com
#36 |
13 Licenses & Counting
Trade: Water well drilling & pumps
Palace,
How's that sonic rig working out for you? Is maintenance as big a head ache on those as I hear?
Pierce Kiltoff, CWD/PI, JKA Well Drilling and Well Pumps & Filter Supply - Map Facebook Monroe, Washington, (360)-794-7300 Serving the Entire Seattle Area, including King, Snohomish, & Pierce Counties, WA |
#37 |
The Sonic Rig has been great. We have been drilling since June, have drilled about 16,000 feet. Just routine maintenance so far.
#38 |
Youngster
Trade: Builder / Consultant / Designer
Palacegeo,
I'm fortunate to live/work in an area where horizontal (slinky method) is the norm. Lots are large (2/3 acre) and usually sandy clay soil. This knocks the cost of geo down dramatically. I'm just trying to get an idea of which brand of ground source heat pumps are preferred, and I'd like to get power consumption specs, and things like that. Can you point me in the right direction? Thanks |
#39 |
Cache,
Are you in Logan? Email through my website that is posted in my signature. I don't come to this site often.
| cost of bagged concrete vs mixed on site | 72chevy4x4 | Concrete & Paving | 12 | 11-22-2008 04:05 PM |
| Cost Plus Question | randybelk@comca | Business | 16 | 09-11-2008 10:09 PM |
| employee cost | Travis | Roofing | 10 | 12-30-2006 07:25 PM |
| Using two units to replace one | Atricaudatus | HVAC | 5 | 04-02-2006 10:51 PM |
| Moving air conditioning units | Woodcrafter74 | HVAC | 13 | 02-14-2006 03:19 PM |
