constant low-speed fan, no heat (Carrier)
I have a 1988 Carrier Limited Edition furnace. The blower is constantly running at low-speed, even after cycling power. The heat cycle doesn't start (usually begins with the combustion blower starting up).
The unit won't respond to the thermost at all. No matter what position the thermostat is in, the low-speed blower continues to run. I tried removing the thermostat and it still runs. I also tried manually providing a heat signal (R-W), still runs. I also tried replacing the main blower relay control board, same result.
The secondary voltage coming off the transformer is 26vAC, so the transformer seems fine. Everywhere else the hot control voltage is around 1vAC.
I am thinking it may be the circuit board for the combustion blower, but I have no idea how to diagnose to make sure, and don't want to continue replacing parts unnecessarily.
Does anyone have any ideas to help a guy get heat in the middle of winter???
Brad
