Condensation Pump
Old 08-28-2009, 10:13 AM   #1
johndaprano's Avatar
Trade: Contractor
Condensation Pump
I need to insall a condensation pump in one of my homes. How difficult is this to do?
Thanks,
John
johndaprano is offline
Old 08-28-2009, 10:59 AM   #2
Burritos
bamawildcat's Avatar
Trade: Lectrical
Re: Condensation Pump
Nothing to it. Should take you about 2 minutes.
bamawildcat is offline
Old 08-28-2009, 01:12 PM   #3
Trade: Contractor
I found a condensation pump online (little giant pump). I had a trane installer recently replace my furance/ac unit in my own personal residence, which has a little giant condensation pump mounted to the side of the furnace. The pump that I need to install is for one of my rentals. However, there are two different sizes on the little giant pump website and i don't know which one to buy. Also, does the pumps usually have an auto on/off switch so when they fill up the kick on automatically. I'll probably take a close look at my own furnace/condensation pump first before I install it in the rental.
Thanks for the help.
John
Old 08-28-2009, 08:37 PM   #4
hf05's Avatar
Trade: hvac tech
Sounds like it may be needed on a 92% carrier !!!!!!!!!
hf05 is offline
Old 08-28-2009, 09:44 PM   #5
BCConstruction's Avatar
Trade: Construction
we used to fit pumps like this on certain boilers in the UK. Dont know if they are any good for what your trying to do but might be worth a look.
http://www.allergybuyersclubshopping...th-tubing.html
BCConstruction is online now
Graco Xtreme Mix 185 Spray Pump painter213 Contractor Swap 1 04-07-2010 06:10 PM
Pump short cycles B&C Plumbing 8 06-21-2009 04:13 PM
Condensation question Jim R General Discussion 7 02-05-2009 07:33 AM
Exterior grade sump pump? Jeeper1970 Plumbing 1 12-27-2008 10:16 AM
myson controller pump 3 port?? big moo Plumbing 1 09-02-2008 03:48 PM
