Condensate Freezing On Siding - HVAC - Contractor Talk
Old 01-05-2018, 12:28 AM   #1
srgrif16's Avatar
I am helping a client with an issue related to the condensate line on their furnace. It is a high efficiently LP furnace installed in an attic with a condensate line that drains to the exterior. The line exits the house through the attic soffit. The line was freezing so my HVAC tech installed heat tape to the interior portion of the line and shortened the exterior portion so that it only sticks a few inches below the soffit. He also insulated the exterior portion. Now the line no longer freezes but the draining condensate is forming large icicles on the siding. What is the best way to protect the siding from the icicle build-up? I hesitate to re-extend the exterior portion of the drain line because I fear it would freeze up again. My first though is to install a vinyl gutter down the side of the house where the drain line exits to channel water toward the ground with the theory being that the larger circumference would make it less prone to freeze-ups. Would this work, or are there better alternatives?
srgrif16 is offline
Old 01-05-2018, 05:43 AM   #2
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,124
Re: Condensate Freezing On Siding
It will probably just take a little longer to freeze in the gutter, but it will freeze it shut without heat trace protecting it.
beenthere is offline
Old 01-07-2018, 08:58 PM   #3
paul100's Avatar
Rewards Points: 40
Since it is in an attic, is there any way that you can reroute the line to an existing vent stack?
paul100 is offline
Old 01-07-2018, 11:25 PM   #4
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,467
You’re no General Contractor. What you are calling a gutter is a downspout. Your HVAC “tech” is a subcontractor, “attic soffit” is just soffit, larger circumference makes no difference and yes there are better alternatives.
How much money did you save?
WBailey1041 is offline
The Following 2 Users Say Thank You to WBailey1041 For This Useful Post:
Fouthgeneration (01-24-2018), greg24k (01-08-2018)
Old 01-24-2018, 05:01 PM   #5
airhealth's Avatar
Trade: duct cleaning and air purification
Rewards Points: 36
Hmmm. Having a bad day, huh?
Why is there so much moisture build up in the attic in the first place? Sounds to me as though the attic ventilation is not correct which is going to cause other problems in the future. Suggest looking into that first.
Eric
airhealth is offline
Old 01-24-2018, 08:05 PM   #6
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,843
Add on a sewer pipe/ vent to service the furnace, heat all the piping or install in a heated space, remember to allow for lengthy power outages, so your system is not broken on restart.
Do you have a catchment pan under the furnace if the drain fails to save your drywall etc......
have you notified the authorities of the defective installer actions?
Will your insurance agency pay on such a hack job install if it (keeps on) fails(ings) and damages your house and stuff?
In my State: You'd have to put the faulty install on the buyer notes when trying to pedal the home.... Can't claim ignorance now after posting here.....
10 cent fix, run the exhaust pipe INSIDE a horizontal hot air/return pipe that is closest to the outside soffit. Never tell anyone you work on furnaces ever again....
Fouthgeneration is offline
Production cutting fiber cement siding Windwash Windows, Siding and Doors 18 06-20-2013 03:43 PM
Staining Cedar T&G Siding j_sims Painting & Finish Work 1 05-31-2013 10:30 PM
fiber cement siding issues. chapstick Windows, Siding and Doors 36 08-30-2012 08:14 PM
Shed picture. lmahome Carpentry Picture Post 14 05-25-2012 11:19 PM
Siding & Windows clemens0894 Windows, Siding and Doors 0 03-28-2012 08:55 AM
