Compressor Fan Problem
Old 05-18-2009, 06:55 AM   #1
72chevy4x4's Avatar
I'm trying to diagnose a problem w/ a Ducane compressor in a 3ton split system. When AC is called for, the fan in the compressor either doesn't start or starts slowly. It's not a bearing problem. Voltage at the relay in the unit is at spec. If I give the fan a little 'nudge', it spins slowly, but not at full speed. It's a 1999 unit, probably not a dual stage unit (low/hi fan).
would the problem be indicative of a bad fan or cap?
72chevy4x4 is offline
Old 05-18-2009, 10:54 AM   #2
NICKTECH
NickTech's Avatar
Send a message via AIM to NickTech Send a message via MSN to NickTech
Re: Compressor Fan Problem
yeah, sounds like it. if you give it a spin and it somewhat runs, the cap is usually the suspect.
NickTech is offline
Paslode Problem HomeWS Tools & Equipment 6 03-02-2009 10:32 PM
trane gas furnace problem funcky HVAC 7 01-28-2009 01:51 PM
Hot water problem PLUMBINGITALL Plumbing 7 01-24-2009 11:15 AM
Toilet problem Mike Finley Plumbing 5 11-06-2007 10:21 AM
