Comfortmaker RPJ2 Will Not Ignite - Fan Induced Motor Not Turning On.
Old 12-24-2004, 01:41 PM   #1
roland
rolandt's Avatar
Question
I have a Comfortmaker RPJ2 that when sending a call for heat from the thermostat, the blower motor will turn on but the fan induced motor will not. This seems rather strange as if power is getting to the blower motor why is it that the fan iduced motor will not turn on?
If the fan induced motor will not turn on does that also send a signal to the burner ignition?
Any help would be appreciated.
Roland T.
rolandt is offline
Old 12-24-2004, 04:14 PM   #2
The Doctor is In!
HVAC Doc's Avatar
Trade: HVAC owner
Re: Comfortmaker RPJ2 Will Not Ignite - Fan Induced Motor Not Turning On.
Inducer motor has to activate a pressure switch to continue the signal on to the control board to start the ignition sequence. Possible something got into the flue and keeping the motor from turning, could be a bad relay/control board not turning the motor on or even could be a bad motor itself.
HVAC Doc is offline
Old 12-26-2004, 06:23 PM   #3
danj's Avatar
Check your high-temp limit switchs, sounds like one is open.
danj is offline
Old 12-31-2004, 05:23 PM   #4
nikko's Avatar
open limit continuous blower.Remove plugged filter..
nikko is offline
Problems with Comfortmaker RPJ2 Furnace BSC HVAC 18 12-11-2010 03:12 AM
mdshunk, try this: RPJ2 Gas Furnace similar ignitor prob tpope HVAC 12 04-09-2007 01:25 AM
HELP - I'm freezing - RPJ2 will not ignite wilroy HVAC 7 06-23-2005 11:17 PM
Another Comfortmaker rpj2 problem ramn1 HVAC 3 02-28-2005 06:46 PM
Comfortmaker RPJ II Furnace won't ignite Unregistered HVAC 1 11-06-2004 02:11 AM
