Comfortmaker RPJ II - Rollout Switch
Old 02-22-2004, 01:41 PM   #1
Chris's Avatar
I have a comfortmaker RPJII. I continue to get the five flashes on my error board, meaning an "open rollout switch". How do I correct the problem?
Chris is offline
Old 02-22-2004, 03:05 PM   #2
Steve Wiggins's Avatar
Re: Comfortmaker RPJ II - Rollout Switch
If you had a roll out switch that has opened that means it got too hot from flames coming out the front of the burner area. Luckily the switch prevented your house from catching on fire. Most likely the insides of your furnace have come apart and need to be replaced or the entire furnace replaced. Definately call for a professional to verify this. Sorry to report that furance manufacturers get away with building such cheap flimsy equipment and homeowners fall right into their low priced scheme.
Steve Wiggins is offline
Is this 3-way switch possible? Greg Di Electrical 13 02-27-2007 09:01 PM
Dimmer switch blowing out glock40 Electrical 4 03-13-2006 07:54 PM
smart light switch circuit toastermaker Electrical 7 12-07-2005 11:45 PM
rollout switch open eloid HVAC 3 02-27-2005 12:23 PM
