Unregistered
Guest
Posts: n/a
Comfortmaker Leaking In Bottom Pan
My comfortmaker RPJII has water int he bottom pan that it is sitting in. The unit works fine, but what would the reason be for it to leak and how can I go about fixing the problem.
Any help would be appreciated and thanks |
The Doctor is In!
Trade: HVAC owner
Re: Comfortmaker Leaking In Bottom Pan
Sounds like the secondary drain pan. If that is the case, that means water is not draining from the evaporator coil properly. Either it is something as easy as the primary drain in the coil is plugged up and needs cleaned or could be something worse such as the drain pan is rusted out/cracked or coil is freezing up and causing overflow of water.
This is actually normal!!!! As an Anesthesiologist with this unit in his house (unfortionately) I assure you all u need to do is drain the unit from the black plastic spout (from the bottom of the combustion motor) by attaching a rubber adapter and attaching it to pvc pipe or use flexible tubing and drain it outside the unit to a Condensate pump or to your sump. there is a small "knock out on the side of the unit( right side as you look at it).....I also had to point this out to my installer..Ps if you have any pamplets or parts paper on this unit I would be grateful since my installer lost "all the paper work"
#4 | |
The Doctor is In!
Trade: HVAC owner
Re: Comfortmaker Leaking In Bottom PanQuote:
| Leaking patio doors | Fix-it | Windows, Siding and Doors | 4 | 11-12-2007 07:44 PM |
| Leaking chimney | builderbob | Masonry | 7 | 06-28-2007 11:07 PM |
| How much can you typically take off the bottom of a hollow core door? | Dustball | Windows, Siding and Doors | 7 | 01-18-2007 10:36 PM |
| leaking basement | HUDSONVALLEYEXT | Construction | 4 | 10-12-2006 10:30 PM |
| Flat roof over garage leaking under exterior walk out door | IHI | Roofing | 18 | 05-30-2006 10:28 PM |
