Comfortmaker GUI100 6 Flashes
Old 12-23-2004, 10:26 AM   #1
fiedlerh's Avatar
Question
I have an Inter-City GUI100AD16IN.
Has is been concluded that 6 flashes of the trouble code LED is the flame sensor? White Rodgers control unit.
Anybody have the P/N handy? I left the parts list at home.
Had the furnace apart last month to clean, lube and service everything (which it needed anyhow). Hi-Temp and Rollout tested OK.
Thought the 6 flashes problem was solved, but now it's back. I see it's a common problem with these.
The Comfortmaker unit must have a circuit to cause problems just before holidays.
fiedlerh is offline
Old 12-26-2004, 10:38 PM   #2
fiedlerh's Avatar
Re: Comfortmaker GUI100 6 Flashes
FYI, I installed a new flame sensor and all is well now. For $8, you can't beat it. I'll file and clean the old one so I have a spare. The local HVAC place was very friendly and helpful and suggested if it doesn't cure it, replace the circuit board.
fiedlerh is offline
Comfortmaker Furnace ignition problem J1CS HVAC 2 10-17-2005 02:39 PM
comfortmaker rpj II charleshoward HVAC 2 02-23-2005 11:05 PM
Comfortmaker RPJ2 will not ignite - fan induced motor not turning on. rolandt HVAC 3 12-31-2004 05:23 PM
Please help with Comfortmaker GUK075N12A1 (Long) jeffguay HVAC 2 11-22-2004 10:35 PM
a cold comfortmaker making us uncomfortable benidle HVAC 4 10-19-2004 07:37 PM
