Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 01-15-2007, 11:02 AM   #1
Combustible Air
When people finish basements and close in boiler areas they are confining the air supply needed to feed the flow of fuel burning. So although you can bring in additional air from the other rooms or outside many dont. My question would be if you have a pilot and flame then why isnt it good enough. Is it in-efficency? Working harder than it needs to and cost more to run? Is this the logic here?
tom m is offline   Reply With Quote
Old 01-15-2007, 11:45 AM   #2
Thom
thom's Avatar
Your question isn't clear. Are you asking if the pilot and or flame are present is that not evidence of adequate draw? If that's the question, the answer is obviously, no.
thom is offline   Reply With Quote
Old 01-15-2007, 12:42 PM   #3
You can have flame and not nearly enough combustible air what are the consequences? Im curious. MOST older homes dont have enough air yet there are no problems.
Old 01-15-2007, 01:13 PM   #4
Hurley's Avatar
Trade: HVAC/swimming pools
Incomplete combustion
Without enough free air you're gonna run into two problems if yu have an atmospheric boiler and if there's a pilot that's what you got. One is incomplete combustion which is inefficient combustion. That means carbon and soot clogging the heat exchanger and vent. Two is potentialy dangerous. The flame will pull air from anywhere it can including down the vent which means eventually CO2 will begin spilling into your home.
Hurley is offline   Reply With Quote
Old 01-15-2007, 02:00 PM   #5
Thoroughbred Mopar Man
Trade: Railroad Conductor/ Ex Hvac Service manager
Hi tom m
Hurley is right on the money. With inadeqaute combustion air there is a potential for flame rollout as well as sooting. Both are potentially very dangerous. The one thing most people forget is accomodating flue draft. Most people are only concerend about proper air for combustion. But think about it in the human sense, what goes in must be able to come out or there will be problems.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 01-16-2007, 08:38 AM   #6
Thanks guys well put I see the senerios here. Im not a Hvac guy Im just looking out for situations they do come up. Where will I see carbon or soot build-up that will tell me there is trouble. I cant see into the vent connectors, other than a black air filter on the heat exchanger what should I look for.
Old 01-16-2007, 08:43 AM   #7
Custom Builder
Glasshousebltr's Avatar
tom m you devious devil .....I think it's evident the little lady's making you build a fart room in the basement.
Bob
Bob
Glasshousebltr is offline   Reply With Quote
Old 01-16-2007, 11:34 AM   #8
Hi tom m
You will usually be able to see the first signs of sooting in the draft diverter for the flue, there will be a discoloration inside the flue pipe that sometimes protrudes to the outside of the pipe. The second place will be the burner compartment, you will start seeing black chunks under and on top of the burners. These are just things to look for, these are pointers I am giving, this does not mean that your boiler is sooted up at this point.
Good luck
Rusty
Old 01-16-2007, 12:13 PM   #9
Moderator
Double-A's Avatar
Carrierman hit on the second most overlooked aspect.
You need dilution air for drafting as well as combustion air for any carbon-based fueled appliance.
In answer to your 'older home' question, the older homes were less air-tight in construction, so air was able to move from outside to inside or from floor to floor with ease, so the problem was not as serious as it can be in a more air-tight home. I would size my dilution and combustion air as though this house were air-tight in all cases. You can't have too much air available for efficient combustion and proper draft.
New York Times, July 20, 2006
Double-A is offline   Reply With Quote
Combustible air duct size Mike Finley HVAC 6 06-29-2007 09:06 AM
