Code For Wiring Compressor Disconnect
Old 10-01-2009, 06:15 PM   #1
72chevy4x4's Avatar
what is the code for wiring the AC compressor disconnect? height of the disconnect box and is the lead to the compressor from disconnect supposed to be armored?
72chevy4x4 is offline
Old 10-01-2009, 06:32 PM   #2
BLDG Inspector, G.C
spdtrx's Avatar
Trade: BLDG Inspector, G.C
Re: Code For Wiring Compressor Disconnect
Yes. Protected.
Disconnect in sight of condenser
Disconnect clearance min 30" wide 36" deep. NOT directly behind unit.
Disconnect max height is 79" to switch or breaker.
spdtrx is offline
Old 10-01-2009, 06:47 PM   #3
TimelessQuality's Avatar
Trade: GC/Remodeling
Originally Posted by spdtrx View Post
Yes. Protected.
Is there a disconnect min height?
-Steve
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein
TimelessQuality is offline
Old 10-01-2009, 11:39 PM   #4
Fentoozler
Celtic's Avatar
Where is this coming from?
Celtic is offline
Old 10-02-2009, 07:47 AM   #5
72chevy4x4's Avatar
does this mean wherever the disconnect is mounted there must be open space 18" up and down (of center) and 15" left and right? what about a minimum height from ground-would that be 18"?
Old 10-05-2009, 06:46 PM   #6
Service & Repairs
Magnettica's Avatar
Trade: Electrician
The disconnect must be placed in a readily accessible location and within sight of the equipment it is supplying. NEC 440.14
Readily accessible mostly means not higher than 6' 7" off the ground, and not behind the condensing unit where servicing the disconnect would be a PITA.
The "whip" from the disconnect to the C/U must be identified for the use and the C/U must be properly bonded using an equipment grounding conductor.
Magnettica is offline
Old 10-05-2009, 07:04 PM   #7
BLDG Inspector, G.C
spdtrx's Avatar
Magnettica
Thanks for your help with explaining the clearance.
I guess I need to learn how explain better.
spdtrx is offline
Ansul Fire, Air Conditioning and the Code Brittle HVAC 2 08-28-2009 10:46 PM
Security wire code?? Jason Whipple Low Voltage 24 03-19-2009 09:02 PM
New Code Coming dayspring Business 33 10-04-2008 06:08 PM
