Chimney?
Old 01-17-2009, 07:13 AM   #1
Blissfield Maintenance
tiny's Avatar
Trade: COMMERCIAL&RESIDENTIAL ROOFING& Repairs
Chimney?
Repost from masonary i have a house that is a 1000sqft and the homeowner is switching from gas furnace to a woodburner. what changes if any need made to the terracota liner or can he hook it up and go with the old?
tiny is offline
Old 01-17-2009, 07:31 AM   #2
Plumbing is a Profession
nhmaster3015's Avatar
Trade: Plumbing & HVAC
Re: Chimney?
You need to check with the local fire department or mech. code official.
nhmaster3015 is offline
Old 01-17-2009, 09:55 AM   #3
Sean
SLSTech's Avatar
Re: Chimney?
Even if it passes code - I would get it cleaned & inspected by a professional before starting the first fire
SLSTech is offline
Old 01-17-2009, 11:18 AM   #4
Dr Heat
Dr Heat's Avatar
Trade: hvac
Re: Chimney?
how old is the chimney?
does the liner run the length of the chimney?
what is the size and how high does it extend above the roof?
what is the flue size on the new furnace?
Dr Heat is offline
Old 01-17-2009, 01:10 PM   #5
Tom M's Avatar
Re: Chimney?
I think its legal if its sized correctly, clean with no cracks, missing mortar or obstructions inside the flue. An inspection will definitely be required for an appliance use change.
Tom M is offline
Dangerous Chimney Dilemna The Boss Masonry 27 04-25-2009 09:35 PM
Chimney problem Jack3185 Masonry 2 04-20-2009 09:28 PM
Masonry chimney on new EPA fireplace? GregWCIL Masonry 8 10-28-2008 09:51 PM
Chimney leaks, permeates water beavhut General Discussion 10 09-02-2008 05:40 PM
Questions About a No Good Chimney Bruce Masonry 11 01-02-2007 12:46 AM
