CFM's On 6" Oval Pipe
Old 02-22-2006, 09:10 AM   #1
LWF's Avatar
Trade: Mechanical
Just to settle a bet here at the shop, does anyone know the CFM's that 6" oval pipe carries? Someone believes in only carries the CFM equivalent of 5" round pipe. Where could I find the proof. I have written Sealtite with no reply.
LWF is offline
Old 02-22-2006, 09:47 AM   #2
Teetorbilt's Avatar
Re: CFM's On 6" Oval Pipe
To roughly find an equivilent diameter add together the 2 radii.
Say the oval pipe is 6" X 4". r1 = 3" + r2 = 2" D = 5"
6" X 3". r1 = 3" + r2 = 1.5 D = 4.5"
Albert Einstein
Teetorbilt is offline
Old 02-22-2006, 10:07 AM   #3
Aceinstaller's Avatar
Trade: sub-contractor
6" pipe is designed to carry 100 - 125 cfms in a properly sized system.
oval or round makes no difference as long as it is not damaged or dented, and has a proper takeoff at the trunk line.
Aceinstaller is offline
Old 02-22-2006, 10:18 AM   #4
to use a formula as teetor has shown, you would have to use the actual dimensions of the oval pipe. in which you'll find that the area of the interior of the pipe is exactly the same between 6" oval and 6" round. because 6" oval is like 7" x 3.5".
To make it very simple to explain to your shop buddies. Just take a small piece of unsnapped oval, lay it flat and when you measure it youll find that it is 18". then do the same with the round. For every 1" of diameter in a cirle, you have to add 3" to the circumference. hence the 18" for the 6" pipe.
Old 02-22-2006, 10:43 AM   #5
Teetorbilt's Avatar
I would stick with the area formula. To go to an extreme, take a small length of 6" and run over it with a truck. Your outside dimensions will remain the same while your AREA will be significantly reduced.
Albert Einstein
Old 02-22-2006, 11:04 AM   #6
OK, OK,
I decided to grab the little duct sizing chart from the shelf just to be sure.
The engineers have done all of the formulas for us already:
Max. cfm through runout ductwork:
6" - supply=100cfm return=75cfm
3.25" x 10" stack(6" oval) - supply=100cfm retun=75cfm
These are the maximum allowable cfms through 6" runout ductwork for heat load calclation purposes from the Carrier installation handbook.
Old 02-22-2006, 01:27 PM   #7
PipeGuy's Avatar
Trade: underground
So - if the oval pipe is 3.25" X 10" then r1 = 1.63" + r2 = 5" D = 6.63". Right?
PipeGuy is offline
Old 02-22-2006, 02:24 PM   #8
By the formula given above, that would be correct.
but, it is possible that either the duct sizes given by manufacturers, for the purpose of sales, are rounded to the nearest whole number. or the formula is incorrect, because when I need to convert from oval to round, the pipes will fit togther tightly. therefore they have the same circumferance.
Although flattening a pipe completely would definately restrict flow, it is stated that the 6" oval stack is rated to have the same maximum cfm capacity as the 6" round. This probably has something to do with the static pressure. And the formulas involved with something like this have way too many variables to list.
Old 02-22-2006, 07:40 PM   #9
Teetorbilt's Avatar
You are correct, more or less, on all points. At a given pressure a stricture results in an increase of velocity giving you approx. the same CFM. For HVAC work this is close enough.
Rich, are you baiting me? I didn't think that getting highly technical was appropriate here.
Albert Einstein
Old 02-22-2006, 08:51 PM   #10
PipeGuy's Avatar
Trade: underground
You're like the old fish in the pond Steve - always sniffin' the bate before he bites.
PipeGuy is offline
Old 03-05-2006, 03:55 PM   #11
Projectman's Avatar
Trade: General
Trane offers (Gratis) a CFM calculator... it's a round dual screen tool. Call trane and ask them for one... It allows you to calculate "Oval Ducting"... easy to use.
Pipe comes in schedules: 40/80/120/***heavy. Good Luck
Projectman is offline
Old 03-05-2006, 03:59 PM   #12
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
My old '69 Charger had an 850 c.f.m. Holley double pumper on it. Does this help?
ron schenker is offline
Old 03-05-2006, 04:17 PM   #13
Projectman's Avatar
Trade: General
Drain Pipe denick Excavation & Site Work 18 07-12-2009 04:41 PM
Gas Pipe Question.... drbigfresh Plumbing 9 02-28-2007 03:51 PM
Using Flex Pipe dirt diggler Pool Construction & Enclosures 8 02-25-2007 04:30 PM
Old black water pipe pedro mac Plumbing 4 12-28-2005 04:13 PM
How to trace gas pipe? karma_carpentry Carpentry 15 11-30-2005 11:47 AM
