Carrier Model 58MXA Banging/clicking Noise On Start Up
Old 11-19-2006, 08:50 PM   #1
gsevans's Avatar
Trade: electrical
Unhappy
A banging/clicking noise occurs when my Carrier model 58MXA starts up. it does this for several seconds before it starts. It is a dual heat pump/gass backup system that switches to gas around 40degF
As each banging noise occurs the inducer motor attempts to turn and a click is also audible. The system finally starts but it seems to be getting worse.
Can anyone diagnose?
gsevans is offline
Old 11-23-2006, 01:55 AM   #2
rakes9720's Avatar
Trade: Electrical Engineering
Re: Carrier Model 58MXA Banging/clicking Noise On Start Up
Maybe the inducer blower wheel is loose or damaged. You would have to remove the motor and inducer housing though. Don't do this unless you know what you are doing.
Or, try spinning the little fan on the inducer motor first and see if it turns freely. If not, your problem is most likely the motor or blower wheel.
rakes9720 is offline
Old 11-23-2006, 10:23 AM   #3
gsevans's Avatar
Trade: electrical
Thanks for the post,
I tried that when the clicking/banging occurs I can freely spin the little fan on the inducer motor with no problems. It almost sounds like it is being electrically controlled ????
It dosen't happen all the time.
gsevans is offline
Old 12-09-2006, 03:37 PM   #4
rakes9720's Avatar
It still could be the motor itself, and maybe the electrical connection is bad somewhere, or the control board.
Old 12-09-2006, 07:18 PM   #5
gsevans's Avatar
Trade: electrical
I tracked down the banging part of the noise to the reversing solenoid on the outside heat pump unit. Seems it was switching on and off and the noise was being transmitted thru the lines.
I replaced the defrost timer on the outside unit with an old one that I thought was broken and not it works.
Any one else have problems with Carrier reversing solenoids switching from heating to cooling every few seconds???
gsevans is offline
Old 01-03-2007, 10:41 PM   #6
Thoroughbred Mopar Man
#CARRIERMAN's Avatar
Trade: Railroad Conductor/ Ex Hvac Service manager
Hi gsevans
I am almost sure that your problem will return. What you are describing is the symptoms of a bad defrost terminator. I will almost bet you end up having to replace the defrost terminator.
Good luck
Rusty
#CARRIERMAN is offline
Please Help Me To Start My Business starobin Construction 9 06-14-2007 03:49 PM
Tapping noise ... RobertWilber Electrical 3 09-07-2006 07:22 PM
Furnace-gas forced air- high pitched noise saturn711 HVAC 3 03-25-2006 09:52 PM
Carrier Gas Furnace model 58MXA jimkp HVAC 1 01-16-2006 09:02 PM
