Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 01-16-2006, 05:39 PM   #1
Trade: General contractor
Carrier Gas Furnace model 58MXA
Is it standard for the HVAC guy to tap the vent pipe and combustion-air pipe together prior to exiting the foundation wall? I recently had to look at some work an HVAC guy installed, and there is a tremendous amount of condensation forming (and leaking) from the vent pipe coupling.
jimkp is offline   Reply With Quote
Old 01-16-2006, 09:02 PM   #2
Holt, MI
Trade: HVAC
Tell me if I am wrong, but what you might have is called a concentric vent termination. Inside, it will have one pipe going in straight and another going in at a 45 degree angle. On the outside it will be a cone shaped affair. If there are two seperate pipes coming out, stop reading.
Ok, if it is a concentric vent, try the following: Your condensation should be from the pipe which is going in straight (the exhaust). Follow this back to the draft inducing motor to confirm it. You might get lucky and the installer forgot to glue it together as your source of condensation. If so, try pulling off the cone on the outside. The pipe in the middle just might pull straight out and you can finish the job. Let me know how you do!
Larry
Bestheating is offline   Reply With Quote
Quality of Payne furnace ??? Home Pro HVAC 38 09-29-2009 09:42 AM
Carrier 58GFA furnace problems rakes9720 HVAC 23 01-12-2008 11:45 AM
carrier gas furnace problem mjm0073 HVAC 4 01-30-2007 11:34 AM
Carrier Model 58MXA banging/clicking noise on start up gsevans HVAC 5 01-03-2007 10:41 PM
carrier furnace burner will not light acci HVAC 12 11-05-2005 07:35 PM
