Carrier 58mvp Problem.
Old 01-16-2005, 03:51 PM   #1
BLSousa's Avatar
Question
I have a 5 ton Carrier 58MVP furnace system that is 5+ years old. We purchased the house two years ago and the furnace has continued to give us problems. The house is a 2700 s.f. two story about 8 years old. We have spent over $2,000 with two different service people trying to fix the system. The propblem is that the system takes 4 hours to warm the downstairs from 66 degrees to 69 degrees while it is 40-45 degrees outside. The problem is that the furnace doesn't stay on long enough to warm the house.
The furnace cycles on and off at a rate of 6-7 minutes from start up to start up.
The cycle is :
intitial flame up and warm up
after 2 min. fan turns on
after 1-2 minutes the burner shuts off
after 1 more min. or so the fan shuts off. Fan total run time = 2-3 min.
system silent for one 0-1minute then intial flame up starts again.
Does anybody have any suggestions; this is getting very expensive!
BLSousa is offline
Old 01-19-2005, 12:20 PM   #2
Fritz's Avatar
Re: Carrier 58mvp Problem.
The cycle is :
I dont think a proper set up was done on the system. where are you located?
Fritz is offline
Old 02-12-2005, 10:41 PM   #3
NICKTECH
NickTech's Avatar
Send a message via AIM to NickTech Send a message via MSN to NickTech
There is a whole check list of procedures a technician uses to help pin point the problem ranging from t-stat loction to inlet gas pressure. Have you checked your air filter? If you've have techs there, I would hope that it was one of their first checks. Any how, check it, see if its clean. A dirty filter will not allow heat to leave, over heating it and shutting it down on safety. Make sure your vents are all open for the same reason. Double check your thermostat's loction. Check to see if there isn't a false heat source, ie. a tv, stereo computer, anything that can put out heat and influence the t-stat to shut off early Anything further would constitute a qualified tech. Since you have spent so much money so far, I would recommend a company that only specializes in heating or HVAC service. Even a Carrier specialist. Make them a deal......No fix, no pay.......If ya fix it, I pay ya!
:Thumbs:
NickTech is offline
Well problem paintr56 Plumbing 10 02-09-2007 09:20 AM
carrier gas furnace problem mjm0073 HVAC 4 01-30-2007 11:34 AM
Carrier Central Air Does Not Cool - pipes ice up = possible Air Handler Problem ? Izya001 HVAC 2 11-20-2006 08:33 PM
Carrier 58MVP Furnace Problem-Inlet Pipe Ice Izya001 HVAC 16 02-26-2005 06:26 PM
Carrier 58MVP Inducer Fan Noise? Doug HVAC 9 05-29-2004 03:59 PM
