Carrier 58GFA Furnace Problems
Old 02-09-2005, 07:55 PM   #1
rakes9720's Avatar
Trade: Electrical Engineering
We have an 11 year old Carrier Model 58GFA funace with problems. When the furnace turns on, only the inducer motor runs. We connected a wire to bypass the pressure switch (bad idea) and the gas valve opens and the burners light; however, they are noisier and the touch the top of the hole leading into the heat exchanger. When the blower fan turns on, the flames turn orange like dust is blowing on them. If you open the blower door slightly, the flames go into the heat exchanger as they should. Also, if you remove the filter, the flames turn orange. Also, the fusible link had to be replaced and the draft safeguard switch trips occasionally. Finally, the flue pipe is not as hot as usual and sometimes the pilot light goes out. We recently replaced the inducer motor. I don't know how much (if any) of this is related. Any help would be appriciated. Thanks.
rakes9720 is offline
Old 02-10-2005, 07:13 AM   #2
The Doctor is In!
HVAC Doc's Avatar
Trade: HVAC owner
Re: Carrier 58GFA Furnace Problems
Check the flue pipe for obstructions. I would also make sure the inducer is sealed properly to its mount. Personally, I would call my contractor back and have him come out and and re-check his repair.
HVAC Doc is offline
Old 02-12-2005, 11:01 AM   #3
rakes9720's Avatar
Thanks for answering.
We had the vent pipes cleaned out and checked for blockages (there were a lot of white ashes everywhere), but this did not change anything.
Old 02-12-2005, 09:39 PM   #4
NICKTECH
NickTech's Avatar
Send a message via AIM to NickTech Send a message via MSN to NickTech
What it appears you have is a breach in the integurity of you heat exchanger!
What that means is that the component that seperates your breathable air with the toxic products of combustion (carbon monoxide) is leaking. The tell tale sign is when your blower comes on and pressurizes the system, the leak is allowing the air the blow over the flames. Hence the flame dancing about, and all the soot and ash, and the pilot going out. If your flue was blocked it would over heat, it sounds like the heat is escaping through this crack, and you are expieriencing a cooler flue pipe. Now, your pressure switch is not making; either because it is malfuctioning, or most likely it does not sense the negative pressure drawn thru the combustion chamber because this crack or leak is stealing it, (so to speak).
Carbon monoxide is a killer. Shut the system down, have it tested and replace it!!
:Thumbs:
NickTech is offline
Old 02-18-2005, 03:22 PM   #5
rakes9720's Avatar
Did model 58GFA have a lot of problems. Do heat exchangers fail after 11 years?
Old 02-18-2005, 08:21 PM   #6
Experience Matters
Comfortman's Avatar
the 58gfa was the lowest cost model of its kind with a carrier name on it
they are nothing BUT problems
its next to impossible to keep the inducer motor from sucking the pilot out
ive seen many where the pilot orifice was improperly enlarged just to end the nightmare of callbacks
do yourself a favor and replace it
i also agree with the above post that you may have a cracked heat exchanger
its just not worth it...they have come a long way in 11 years
Comfortman is offline
Old 02-20-2005, 02:21 PM   #7
NICKTECH
NickTech's Avatar
sure they do, i've seen them go as soon as the next year after install. there a a lot of contributing factors. As a general rule of thumb, a furnace life expectancy is about 12-15 years.
NickTech is offline
Old 02-21-2005, 05:54 PM   #8
rakes9720's Avatar
Thanks for the help. I've heard that Goodman furnaces are not reliable, and I also heard that Amana furnaces are high quality, and this year, an advertisement says that Goodman now uses Amana technologies. Would Goodman be a good choice now or not?
Old 02-22-2005, 08:07 PM   #9
Experience Matters
Comfortman's Avatar
ill give you three guesses who makes amana equipment and the first two dont count
the amana is however their higher end line and fewer corners are cut
Old 02-23-2005, 05:36 PM   #10
tinner73's Avatar
you have a dog of a furnace now. don't make the same mistake with a Goodman/Amana. look into a Rheem or something comparable. this isn't a good time to be cheap, you'll have this furnace for a long time.
tinner73 is offline
Old 02-25-2005, 03:31 PM   #11
rakes9720's Avatar
Are Carrier furnaces more dependable now, or should I find another company like Rheem?
Old 02-25-2005, 06:14 PM   #12
tinner73's Avatar
Rheem is good.
tinner73 is offline
Old 02-26-2005, 12:21 PM   #13
rakes9720's Avatar
Thanks for all the help, and sorry for so many questions. Took off the inducer motor to look, and everything inside is black like carbon deposits. It was silver colored before. Any ideas on why it is there?
Old 03-19-2005, 11:25 AM   #14
rakes9720's Avatar
On Wednesday, the furnace exploded, waking people up, splitting all four heat exchangers, blowing the chimney cap off, and throwing ash in the basement and on the roof. Definatly time for a new one!! Not sure on what caused it, but it will not light without holding a torch in front of the burners, and the fan blows the flame completely out of the furnace because of the cracks. We have been running the heat pump (furnace blower running), is this okay, or should we not use the furnace at all? Thanks
Old 03-19-2005, 05:39 PM   #15
NICKTECH
NickTech's Avatar
ummmmmmm.........
NickTech is offline
Old 01-02-2008, 03:12 PM   #16
vlux's Avatar
Trade: hvac
shame on you techs[?] for bashing a furnace manufacturer. I have installed Goodman for years without problems. Look at the components on a lot of differant furnacesv and you will be surprised at the similar parts or manufactures. All furnace manufacturers have there share of bad models. Dont bash guys, unless you have logitimate reasons. JMO Victor
vlux is offline
Old 01-02-2008, 04:06 PM   #17
HVAC Old Timer
HeatPro's Avatar
Trade: HVAC
I guess this was dredged up from 2005 to boost something. The question as to whether to use the Carrier furnace that blew the heat exchanger apart for the blower only for the heat pump was amusing - and not answered. Guess many thought the guy was joking around. I wonder what he has now - or if he's alive.
There were Goodman problems in the distant past that made a rep; but the newer tube exchangers don't seem to have complaints. Furnace manufacturers have no plans to continue failure - it just doesn't make money.
http://johnmills.net/hvacshots/pages/gmpheatex.html
This popular 80% furnace has been sold since the early 90s. The first few years of production have been suffering from failed crimp rings on the heat exchager. The cells are held together by the rings punched as you can see. But in the circled case, the ring failed allowing the metal to separate as it heats up. First symptom is tripped rollout switch because the draft is reduced and the flames aren't pulled in. Goodman was offering some labor allowances so check with your supplier if you find a bad one.
http://www.cpsc.gov/cpscpub/prerel/prhtml01/01189.html
HeatPro is offline
Old 01-02-2008, 04:18 PM   #18
Was interesting to see that the guy was soooo stubborn
that he actually kept putzing around til it literally blew up!
neolitic is offline
Old 01-11-2008, 03:50 AM   #19
HVAC Contractor
GreaseMonkey's Avatar
Trade: HVAC Contractor
Sounds like this guy is pulling everyones leg here, i.e. still trying to light it after all four heat exchangers have blown apart.
GreaseMonkey is offline
Old 01-11-2008, 08:33 AM   #20
HVAC Old Timer
HeatPro's Avatar
Trade: HVAC
Yeah. There are extra 'flame' points if you can look like you confused a pro by confusing a novice. Time on hand.
HeatPro is offline
Quality of Payne furnace ??? Home Pro HVAC 45 03-30-2010 10:10 PM
carrier gas furnace problem mjm0073 HVAC 4 01-30-2007 11:34 AM
Carrier Gas Furnace model 58MXA jimkp HVAC 1 01-16-2006 09:02 PM
carrier furnace burner will not light acci HVAC 12 11-05-2005 07:35 PM
Carrier Pressure Switch Problems KMH HVAC 4 10-02-2004 11:00 AM
