Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 02-24-2008, 12:57 PM   #1
Trade: Wahl Construction
Carrier 58DFA gas furnace problems
Have a Carrier Gas Furnace (model 58DFA) that’s giving me problems; it’s the weekend so no shops are open and its getting cold! I’m more of a plumbing/construction type so I’m venturing into somewhat unchartered territory here….so, appreciate the assist!
Was working fine but now the main gas jets aren’t firing; pilot light’s on, blower fan activates, fuse is good, filter’s clean, and no flipped circuit (or switches) breakers. Replaced the thermostat with a Honeywell unit (no big deal, wanted a programmable one anyway) and have ran the checklist that came with the unit as best as I can to check the board (VAC test etc.) but have hit snags where I’m not 100% sure what/how to proceed. Ex. Below.
- 24 VAC across gas valve: ?
- 24 VAC across pressure switch No contact & screw C on board ?
- 24 VAC across PL1-2 & screw C on Board ?
Just trying to do what I can & if I can get it running well, the heat will be welcome! Not sure how complete this checklist is but almost all of the end-roads do point to replacing the circuit board (?)
Again; any help you folks can provide is most welcome!
KMoses is offline   Reply With Quote
Old 02-25-2008, 01:16 PM   #2
Problem FIXED!
The Inducer Fan bearing was begining to fail and the additional voltage needed to operated was tripping the heat/safety switch. Replaced and it's working fine again.
Quality of Payne furnace ??? Home Pro HVAC 38 09-29-2009 09:42 AM
Carrier 58GFA furnace problems rakes9720 HVAC 23 01-12-2008 11:45 AM
carrier gas furnace problem mjm0073 HVAC 4 01-30-2007 11:34 AM
Carrier Gas Furnace model 58MXA jimkp HVAC 1 01-16-2006 09:02 PM
Carrier Pressure Switch Problems KMH HVAC 4 10-02-2004 10:00 AM
