Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 12-24-2007, 11:33 AM   #1
Trade: Remodeling / Tile Installer
Carrier 48SS
I have a carrier model 48ss. Last year, we had the burner replaced due to it having holes in it from being old, as well as the blower fan motor. Well this year, the system will turn on, the heat will kick on in the house, and then sometimes, it will cut off but the system will still be running. The only way to shut it off so that the $$$$$ isn't going out the roof is to cut it off at the breaker. Does anyone have any advise on this matter?
jtfussell is offline   Reply With Quote
Old 12-24-2007, 11:57 AM   #2
HVAC Old Timer
HeatPro's Avatar
Trade: HVAC
quote: "it will cut off but the system will still be running."
The IT is the problem. As the furnace is part of the system, IT cuts off, but we don't know what that is. Usually the heater continuing to run is due to a sticky relay or a shorted wire. Certainly, having no control of the burner is a severe problem that can burn the exchanger and suffocate you, so finding the particular IT is necessary. The safest course is to turn it off until someone who knows the electrical troubleshooting procedures for electrical furnace circuits can find and fix the reason the IT turns off, but not the flame.
HeatPro is offline   Reply With Quote
Old 12-24-2007, 07:42 PM   #3
Trade: General contracting including bathrooms, kitchen, roofing, basements, and full rehab.
I agree you have a serious and dangerous situation. It's really time to get another furnace. I would check the control board. Sometimes the soldered connections get loose from the heat or something gets burned up. Your limit switch by the exchanger is supposed to send a signal to the board to shut off the gas valve. Another possibility is bad valve (not as likely though) that won't shut off. So check the voltage there.
I would highly recommend retiring the unit. If there's a hole in the exchanger, you're going to suffocate like HeatPro said.
riggs is offline   Reply With Quote
Carrier 48SS Heat Exchanger Rupture bengineer HVAC 4 11-20-2009 05:25 AM
Carrier / ICM bypass timer mdshunk HVAC 0 10-30-2007 05:40 PM
Insurance carrier in NY? Rayman Business 0 04-24-2007 03:13 PM
Carrier Model 58MXA banging/clicking noise on start up gsevans HVAC 5 01-03-2007 10:41 PM
Carrier 48ss Dave-0 HVAC 4 06-26-2005 08:14 PM
