Trade: A/c
Can I Install A A Coil In A Down Flow Furnance
Can I install a A coil in a down flow furnance?. How much water run down the duct?. Is the top part of the coil going to freeze to much? .
Thom
Re: Can I Install A A Coil In A Down Flow Furnance
Yes, we do it regularly.
Won't be any if you install it correctly. You must properly drain the "A" coil. Not if the system is correctly installed. |
Trade: Electrician
How would you properly drain the A coil ?....My new downflow seems to have water blowing right off the coil and missing the drain pan....I had to seal the supply box and run a seperate drain hose........Is there a better idea?
| coil replacement | kyhtb | HVAC | 11 | 02-19-2009 08:26 PM |
| Alright businessmen ... I'm gonna give it one more try ... breakin even | dirt diggler | Business | 30 | 02-27-2007 12:34 PM |
| Hydro Air Coil | ofourcobra | Plumbing | 4 | 10-16-2006 10:17 PM |
| correct way to install | Michaela521 | Electrical | 1 | 08-13-2006 05:36 PM |
| Steel/vinyl coil stock. What to look for.. | GiantScale | Roofing | 2 | 04-13-2006 07:38 PM |
