Can I Add Cold Air To A Existing Hot Air Furnace
Old 10-06-2009, 10:01 PM   #1
metzade's Avatar
Trade: gc
Hey
i am currently doing a commercial storefront job and the owner had a question for me that i had no idea how to answer he currently has a furnace unit but it only handels the heat and he wanted to know what his options were for cooling and i wasnt sure if you would be able to add a cooling unit a compresror to the existing furnace to supply cold air through the existing ducts, and what other options does he have besides a standard air condtioner
metzade is offline
Old 10-06-2009, 11:02 PM   #2
Anti-wingnut's Avatar
Re: Can I Add Cold Air To A Existing Hot Air Furnace
The answer is yes, a coil set can normally be added either above or below the furnace, with the furnace air handling system moving the air for the combined unit. A compressor will ahve to be added outside if the system is to be a split system, which seems likely.
I am not an HVAC guy, but have been around many commercial sites, and my father was President of the MCA.
Anti-wingnut is online now
Old 10-07-2009, 01:33 PM   #3
Thom
thom's Avatar
Have an HVAC company look at the existing unit, they can give you a real answer. From this side of the monitor, the answer is, maybe yes, maybe no. Sometimes A/C can be added to an existing system, Sometimes it requires a new furnace, sometimes it requires other modifications.
thom is offline
Energy Tax Credit AC and/or furnace? Warren HVAC 3 07-02-2009 10:26 PM
furnace blowing hot and cold air banctecbobn HVAC 1 01-17-2009 11:32 AM
Problematic furnace diagnosis on a cold day cleveman HVAC 0 01-13-2009 11:45 PM
very cold outside air from cold air return ?? slawek HVAC 3 12-24-2008 09:30 AM
FDA to declare cold medicines too risky for babies, toddlers eagleandbaby Off Topic (Non Trade) 0 01-17-2008 09:36 AM
