Originally Posted by HVAC Doc
Actually if you clean the connection good, by the time you hit it with the oxy/acet torch and get the joint hot enough for stick braze, there won't be much (if any) of the soft solder left.
Yeah, by that time all of the soft solder will be inside the system due to capillary action ... where it should not be.
To repair a leak:
1. pump down refrigerant into condenser.
2. cut out problem area on copper lines
3. install new fittings and solder in (using proper soldering technique)
4. also solder in a new liquid-line filter-drier.
5. evacuate system to proper level (using proper evacuation technique)
6. leak check
7. charge to manufacturer's specifications (using proper charging technique)
8. leak check
Thank you and have a nice day.
