Burner Motor Sticks
I have an oil burner that sticks when it try's to fire up some of the time. If you push the reset and lightly tap it it fires up?
Nick "Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein |
HVAC Old Timer
Trade: HVAC
Re: Burner Motor Sticks
Sometimes, tapping makes a better connection somewhere near the tap, so cleaning and tightening connections as part of the annual service procedure can overcome a problem. I've also had some motors lose a winding, making a 'flat-spot' in the motor to hang at that one point, or have dirty contacts. There isn't a one-shot 'always works' for a 'tap' question, some checking will be required before buying a new one.
#3 | |
Electro-Mech. Contr.
Trade: Mechanical Contractor
Re: Burner Motor SticksQuote:
Replace it, they don't cost more than $70, is it worth a freeze up trying to save it?
"Injustice anywhere is a threat to justice everywhere" mlk 100% Union and Proud of It |
| Oil Burner Problems | junior437t | HVAC | 27 | 12-17-2009 12:09 PM |
| Oil Burner Igniter | KGB | HVAC | 2 | 03-03-2007 09:09 PM |
| hallamrk "O" burner not running right | johngeen | HVAC | 0 | 10-22-2006 10:17 AM |
| gas furnace pilot and burner cut off after a few minutes | Shinola | HVAC | 4 | 12-17-2005 08:17 PM |
| Goodman Gmp075-3 Burner Intermittant | DMC | HVAC | 1 | 03-06-2005 04:54 PM |
