BTU Requirements
Old 04-29-2009, 03:55 PM   #1
Haydin's Avatar
BTU Requirements
Just looking for a ball park? What size BTU radiant heat boiler would you spec for a commercial building with these parameters: 50' deep x 60' wide ( 3000 SF ). Steel building with 10' side walls and roof ridge at 12' ( figure average 11' clg ). R-19 insulation walls and roof. Insulation thickness is compromised every 4' O.C. where it is sandwiched between the siding and structural members ( figure average R-10 ). (12) ground loops at 250' each and 1/2" diameter under 4" concrete slab. 3/8" styrofoam insulation under ground loops / slab. 5 degrees exterior temp minimum. a 2'x2' window and 2'6 x 6'8 door. Thanks for any help, karl
Haydin is offline
Old 04-29-2009, 04:35 PM   #2
Professional Instigator
rbsremodeling's Avatar
Re: BTU Requirements
a big one?
rbsremodeling is offline
Old 04-29-2009, 05:00 PM   #3
Haydin's Avatar
Originally Posted by rbsremodeling View Post
a big one?
Yeah? But HOW BIG? 50K? 100K? 150K?
Haydin is offline
Old 05-01-2009, 07:37 PM   #4
beenthere's Avatar
Trade: HVAC
Wirsbo has a heat loss calculator you can use to size it.
beenthere is offline
insurance requirements dayexco Roofing 17 04-26-2009 07:39 AM
ventilation requirements on boiler rm door 72chevy4x4 Construction 1 03-10-2009 09:20 AM
Requirements for pulling permits? Rx8 General Discussion 38 02-15-2009 09:59 AM
State work and requirements J-Peffer Business 2 01-26-2009 01:23 PM
TX insurance requirements? Mike Meyering Help Wanted or Looking For Work 0 09-20-2008 08:36 AM
