Bryant RTU
Old 08-25-2008, 02:12 PM   #1
A.D. Const's Avatar
Trade: A.D. Contracting & Remodeling LLC.
Bryant RTU
Hi, I have a Bryant RTU Model # 580fpv240360abcd. The fusible blug blew due to to fan problems and high head sensor that did not shut the unit off. Problems have been taken care of. However, I want to re-charge the unit by weight, can anyone tell me the proper weight of refrigerant for this unit. As you may see from model # this is a 2 compresor, 2 fan unit. I only lost one side (secondary). Also for any other Bryant rep any other info would be greatly appeciated such as tons, year made, seers rating or any available info. Thanks
A.D. Const is offline
Old 08-25-2008, 10:58 PM   #2
flashheatingand's Avatar
Trade: H.v.a.c.
Re: Bryant RTU
why would you want to recharge the unit? If I am reading your post right, you had an electrical problem not a problem with the refrigerant circuit. You should not need to mess with the refrigeration if all was ok earlier.
flashheatingand is offline
Old 08-26-2008, 09:23 AM   #3
A.D. Const's Avatar
Re: Bryant RTU
Well yes, it was an electrical problem, but the fuzible plug melted, as a result, do to high preasure/high temp. so the unit lost it's charge. Thanks for the reply
Old 08-27-2008, 01:11 AM   #4
Trade: H.v.a.c.
Re: Bryant RTU
Gotcha,
I believe the factory charge is listed on the nameplate.
otherwise, I would call the local bryant/carrier supplier, they could tell you the factory charge, and take it from there.
Old 08-27-2008, 02:24 PM   #5
A.D. Const's Avatar
Re: Bryant RTU
Thanks, appreciate your input. I do have a # on the unit (13lbs), but its hand written, I figure I could verify. How about owners manual?, Munufacturers site does not have. Is there any site that would recollect this info? Its probably a long shot, but its worth a try. Does any one know where else to find. Thank you
Old 08-27-2008, 07:30 PM   #6
HVAC Tech, NATE certified
Verbal's Avatar
Trade: Hvac technician. Boehmer Heating
Re: Bryant RTU
weighing it in will get you realy close, but SH and SC would get you just about dead on.
Best line from a customer "you here for the tune-up? the tank of 22 is in the shed, let me know if you need more."
Verbal is offline
Old 08-28-2008, 04:19 PM   #7
A.D. Const's Avatar
Question
Re: Bryant RTU
Maybe you can explain that a bit clearly. Not to be doubtful, but I still don't understand the concept of SH/SC. I have read a lot about it, but it is my understanding that manufacturer's preffer a weight in charge. As a matter of fact it is my understanding, they (manufacturers)weight in their's charge to new manufactured units. How then would the super heat/sub cool method be more accurate?
I don't mean to second guess you, most likely, you may be right, but I most understand the concept behind it or I'll, or any other reader of this post, may do it wrong. I can't see anything more secure that a weight in charge. Only my opinion though.
Can anyone help with an older Bryant Model # A.D. Const HVAC 5 06-24-2008 08:08 AM
Bryant 398AAV furnace intermittent fiedlerh HVAC 5 02-28-2005 09:30 PM
Bryant 90Plusi Running in Emergency Heat Mode Unregistered HVAC 2 03-01-2004 03:57 AM
