Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 02-10-2004, 06:59 AM   #1
Unregistered
Guest
Trade:
Posts: n/a
Bryant 90Plusi Running in Emergency Heat Mode
I have a Bryant 90Plusi gas upflow furnace that was installed in late 1989. The model is 398BAZ, 60,000 btu.
Is there any problem running in the Emergency Heat mode?
Will it cause problems, degrade other components, alter the amount of heat coming through the vents, run inefficient, etc?
Old 02-26-2004, 02:21 AM   #2
drpsr69
Guest
Trade:
Posts: n/a
I assume you have a heat pump to have a tstat with a emergency heat position.If so this will not hurt anything it just runs the furnace .
Old 03-01-2004, 03:57 AM   #3
Unregistered
Guest
Trade:
Posts: n/a
Explanaton of emergency heat mode
No, this is not a heat pump. It is a natural gas upflow furnace but it is the premium model because it has variable speed inducer and blower motors. The emergency heat mode bypasses the microproceesor control board and sets the motors into high speed. The blower motor is turned immediately when the thermostat is met instead of having a delayed turn-off.
Dave P.
Tricks to sizing a heat pump Danno6102 HVAC 1 06-28-2007 05:05 PM
heat pump help!?!!! maxkd HVAC 1 11-10-2006 08:57 PM
Ceramic Additives Nathan Painting & Finish Work 41 03-01-2006 07:52 PM
Heat Pumps naturenut HVAC 3 01-27-2006 02:03 AM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 03:38 PM
