Boiler Plumbing Question
not sure if this should be in plumbing or hvac...
I'm looking at a boiler system that failed the 5 year inspection b/c the supply into the boiler has a 'T' w/ the pressure release valve on one side. The inspector said the shutoff valve should be between the pressure regulator valve and the boiler and also the pressure release is not supposed to be mounted on the same leg the water supply is located. There is more plumbing located on the boiler-is there a certain place the pressure relief valve should be mounted-or can I tap in anywhere? |
Re: Boiler Plumbing Question
[IMG]file:///G:/DCIM/101MSDCF/DSC02144.JPG[/IMG]
Here is a picture of the boiler-sorry I couldn't figure out how to rotate it. The supply is the tube coming from the top (if rotated 90 degrees) which feeds into the 'T' and has the pressure relief valve on one side and supply into the boiler on the other. Where should I move the pressure relief valve to? |
Trade: plumbing heating &ac
the relif valve is usaly located coming out of the top or rear of the boiler should be piped so the inlet of valve is vertical so it doesnt fill with sediment and should be piped 6 inches from the floor with a 45 deg angle cut on pipe so it cant be capped but some boiler manufactures give you a header to come off boiler supply with the gauge like buderus . Watts makes a combination feed and relif valve wich would put safety valve in the boiler feed the only reason I would not use one is youre suposed to have a shut off on both sides of the auto feed and by code you cant have a shut of piped before a relif valve.
| Question about bidding vinyl wallcovering | kanadaeh | Painting & Finish Work | 9 | 02-19-2009 05:29 PM |
| plumbing codes question for new construction?? | national | Plumbing | 19 | 07-12-2007 05:54 AM |
| Locating plumbing in an outside wall | Mike Finley | Plumbing | 15 | 09-09-2006 07:49 AM |
