Blower Noise On Startup
Old 03-09-2009, 12:01 AM   #1
banctecbobn's Avatar
Trade: home builder
My blower motor makes a noise and is slow to startup. Once it gets going it runs fine with no noises. I changed out the 22,000 cap with a 10,000 cap and the motor wouldn't get going (this was the only cap onhand). I put both caps together (parallel) and the motor starts up much quicker with little to no noise.
Do you think my orginal cap is going bad or is the starter windings in the motor on the way out and by adding the additional cap it is masking the problem? Don't want to buy a motor if all it needs is a new cap.
Goodman 2 stage multispeed gas furnace.
banctecbobn is offline
Old 03-09-2009, 06:17 AM   #2
beenthere's Avatar
Trade: HVAC
Re: Blower Noise On Startup
Its possible.
Its also possible your burning up the motor with the current cap set up you did.
beenthere is online now
Old 03-09-2009, 10:22 AM   #3
Geno54's Avatar
Trade: HVAC
You will do more harm by not using the correct size capacitor. The wrong size cap could eventually overheat the motor and burn it out. You need a multi meter to check these out.
Geno54 is offline
Old 03-09-2009, 01:44 PM   #4
NICKTECH
NickTech's Avatar
Send a message via AIM to NickTech Send a message via MSN to NickTech
use a capacitor testor to see if you are getting the proper MFD. usually 3 to 5 MFD, but check to be sure. a plus or minus of 10% is allowed.
NickTech is offline
Fs: Unisul volumatic iii itch blower elinelson Contractor Swap 1 02-17-2011 09:52 AM
Insulation for noise factor downtown? SHARONCRAFT Remodeling 5 03-10-2009 10:42 PM
Furnace Blower for sale graart HVAC 1 01-24-2009 11:40 PM
Help - how to reduce noise at heating vent j97chung HVAC 3 01-03-2007 10:08 PM
Tapping noise ... RobertWilber Electrical 3 09-07-2006 07:22 PM
