Blower Motor Constantly Running
Old 05-06-2007, 06:56 PM   #1
newcomer08's Avatar
Trade: hvac
Send a message via Yahoo to newcomer08
What are some possible causes for the blower motor to continuesly keep running... I replaced the relay but that did not solve the problem..
newcomer08 is offline
Old 05-08-2007, 08:17 PM   #2
snapperhead's Avatar
Trade: commercial hvac repair and installations
Re: Blower Motor Constantly Running
take the stat off the wall with the subbase still wired.if the fan stops there is something in the stat that is calling it in...check the configuration if it has oneif it stays on head for the air handler.remount stat...down at the air handler pull the G wire off with it running if it stays on it is something within the air handler...if the G wire and the R wire are rubbing togeather any where between the stat and the air handler that will call the fan in...disconnecting the things above will isolate whats causing it to run.
snapperhead is offline
Old 05-11-2007, 08:09 PM   #3
Thoroughbred Mopar Man
#CARRIERMAN's Avatar
Trade: Railroad Conductor/ Ex Hvac Service manager
Hi newcomer 08
Some of the manufacturers use the blower as a warning device as a loss of low voltage. Some of them wire through the limit circuit of the furnace. If its a Carrier, Bryant or Payne this could be the case. Need any more information if you give us a little more to work with, one of us can help you pinpoint it.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline
Old 06-07-2007, 11:43 PM   #4
Astar Heating & A/C CEO
FemaleAstarCO's Avatar
Trade: HVAC Contractor
Send a message via Yahoo to FemaleAstarCO
Start jumping out your roll outs. Often it is your roll outs or snap switches.
FemaleAstarCO is offline
What is everyone running for Fiber in new home Construction? voiceguy Low Voltage 9 04-09-2008 06:20 PM
running 220 for 125 feet fast pasquale Electrical 34 05-03-2007 08:39 PM
Goodman GMT045-3 Blower problem GaryStevens HVAC 2 02-23-2007 12:17 AM
Is your business running YOU or are you running your BUSINESS? Mr. Wms General Discussion 21 01-27-2007 02:47 PM
difference between running a bus. and a contracting bus. dirt diggler General Discussion 22 11-01-2006 06:45 PM
