Bid For New Furnace Raises Questions
Old 10-27-2009, 09:14 AM   #1
Dairylander's Avatar
Trade: Renovator
Question
Mom's furnace is on its last legs, so I got a bid to replace it.
The guy wants to change out the AC coil at the same time, even though it's only 6 or 8 years old. Here's what he said:
"New Modulating Furnace, 95% eff, AND new AC coil, because the new coil is compatible with the newer (green) coolant gas -
so that whenever the old AC unit (outside) dies, you only have to replace the outside unit, and not tear-out/change the AC coil inside also."
$4700.00
Is this logical or recommended?
Is it really so hard to change out the AC coil at a later time?
Why would he be pushing to do it all at once?
What do you guys think about the price? Seems a little steep to me.
Lastly, is a two stage furnace worth the extra $?
Thanks.
Dairylander is offline
Old 10-27-2009, 09:19 AM   #2
genecarp's Avatar
Re: Bid For New Furnace Raises Questions
Dairylander, welcome to CT, go to the intro page and introduce yourself to the guys, and tell us a little bit about your business, also complete the profile, thanks GMOD
genecarp is offline
Old 10-27-2009, 10:23 AM   #3
You did what??
J F's Avatar
J F is offline
Old 10-27-2009, 10:25 AM   #4
Illusion of Perfection
CookeCarpentry's Avatar
I still love the GMOD signature....
CookeCarpentry is offline
Old 10-27-2009, 10:25 AM   #5
cbowma4's Avatar
Trade: HVAC
It would seem the end result in that would be r22 (your current refrigerant) going through a coil meant for r410a. So when you installed a new condenser, the coil would have to be properly flushed to not damage the equipment. I think there would be less overall hassle, as well possibility of problems, doing the coil and condenser all at once.
Also, what are the features of the furnace? (just curious) Does the bid already include a two stage furnace? You mentioned modulating, is it a modulating gas valve, or a variable speed blower?
cbowma4 is offline
Old 10-27-2009, 10:31 AM   #6
You did what??
J F's Avatar
Originally Posted by genecarp View Post
cbowma4, welcome to CT, go to the intro page and introduce yourself to the guys, and tell us a little bit about your business, also complete the profile, thanks GMOD
J F is offline
Old 10-27-2009, 10:32 AM   #7
Nice use of plagiarism, JF.
Old 10-27-2009, 10:34 AM   #8
You did what??
J F's Avatar
I considered it more of a "helping hand"
J F is offline
Old 10-27-2009, 10:36 AM   #9
Semantics....looks like the o/p chose to check out instead of posting an intro....some "renovator"...
Old 10-27-2009, 10:38 AM   #10
and the hvac guy left too.....well we must not be doing too good of a job welcoming newcomers to this site...
Old 10-27-2009, 10:49 AM   #11
You did what??
J F's Avatar
it's all gmoddiddy's fault, diddy-did-it
J F is offline
Old 10-27-2009, 11:26 AM   #12
genecarp's Avatar
http://
genecarp is offline
Old 10-27-2009, 01:48 PM   #13
Trade: Renovator
I had to go to work. Sorry that my laptop doesn't fit in my tool belt.
Cooke must be the welcome wagon...
Old 10-27-2009, 01:50 PM   #14
As you can tell, I don't do a good job of it.
Old 10-27-2009, 01:55 PM   #15
Trade: Renovator
I don't know much else about the unit except that it's a Coleman. The bid does include the two stage and would cost $800 less with a single stage. I'm not sure about the modulation. Are variable speed blowers problematic?
Old 10-27-2009, 02:04 PM   #16
Trade: Renovator
All right, no problem.
Hello, my name is Dairylander and I'm an alcoho... wait, nevermind.
Old 10-27-2009, 03:05 PM   #17
You did what??
J F's Avatar
J F is offline
Old 10-27-2009, 07:37 PM   #18
jgray152's Avatar
Trade: Faux Rock Creations
jgray152 is offline
Old 11-01-2009, 06:30 AM   #19
beenthere's Avatar
Trade: HVAC
I don't know much else about the unit except that it's a Coleman. The bid does include the two stage and would cost $ less with a single stage. I'm not sure about the modulation. Are variable speed blowers problematic?
VS blowers are not problematic. When installed properly.
The Coleman mod comes in both a VS version, and a PSC blower version.
As far as changing out your A/C coil at the same time as the furnace.
The A/C coil is NOT a part of the furnace. And it is to be matched to the outdoor unit. Unless you already know what outdoor unit you will get 5 or 6 years down the road. It make no sense to change it now and still use the current outdoor unit, If it is not leaking.
It may make sense to change out the outdoor unit along with the furnace now. If you get a unit with a high enough efficiency to qualify for the up to $1500 tax credit. Ask him for prices on units that meet the requirements. And then decide.
beenthere is offline
The Following User Says Thank You to beenthere For This Useful Post:
Dairylander (11-01-2009)
Old 11-03-2009, 10:11 PM   #20
Dr Heat
Dr Heat's Avatar
Trade: hvac
First your old R22 unit will contaminate the new coil making it necessary to clean or better change the New coil if installing a 410 A
Second to install the coil the tech will need to extra work.
Third because the Company bidding this Job should Know this I would not trust them at all.
Fourth 4,700 is High for a furnace even a High End Colman is not high end.
Just my opinion
Dr Heat is offline
The Following User Says Thank You to Dr Heat For This Useful Post:
Dairylander (11-04-2009)
Posting Rules Update: How-To Questions Nathan General Discussion 1 09-21-2009 03:33 PM
Direct vent furnace draft inducer ArmstrCarpentry HVAC 4 07-26-2009 12:45 PM
Energy Tax Credit AC and/or furnace? Warren HVAC 3 07-02-2009 10:26 PM
Pricing questions Brian Painting & Finish Work 3 10-13-2007 09:38 AM
Questions About a No Good Chimney Bruce Masonry 11 01-02-2007 12:46 AM
