Trade: RESIDENTIAL REMODELING
Bath Fan/heater
Am remodeling a bath.
Current bath/heater/light/fan is "attached" to the side of the joist instead of "between" the joist on hangers. Am replacing the unit. Does the unit, I guess because of the heater, need to be "between" the joist instead of attached to making metal/wood contact? Thanks John |
Capra aegagrus
Re: Bath Fan/heater |
Trade: GC, Elec, Plumb
Re: Bath Fan/heater
As the heat lamp/element is reflected down and out, it requires a clear space (as set by the manufacturer). This is refering to walls, towels, etc. In the instructions, it should say if there is any restrictions for mounting (i.e. if it is IC <insulation contact> rated or not). Unless it specifically states the it can not be mounted to or near combustible material, then you are OK.
#5 | |
Re: Bath Fan/heaterQuote:
It is a "coil" type heater, not a lamp! Thanks Joh |
Re: Bath Fan/heater
Makes no difference. That is why I said "lamp/element" for either one. They are made to reflect the heat down and out. If it has no restrictions on the actual mounting (ie: non-IC rated, do not mount to or near combustible materials, etc.) then just made sure it is more than 12" (if that is what it requires) from the wall. Most fixtures are made with the knowledge and intent that they will be mounted to the wood framing in some manner. It is the insulation that is the real issue. Again, find out if it is IC or non-IC rated, and follow the installation instructions for whatever the case may be.
| The Following User Says Thank You to joelv1967 For This Useful Post: | John1 (04-15-2009) |
| Bath Fan/heater | John1 | Electrical | 12 | 04-15-2009 08:56 PM |
| Bath ventilation fan/heater combo | drb9 | Kitchens & Baths | 5 | 12-22-2008 09:13 AM |
| tile backer in a bath room and kitchen | mikeybobo | Drywall | 10 | 12-05-2008 04:31 PM |
| Bath area rock ??????? | Driftwood | Drywall | 9 | 11-24-2008 09:35 AM |
| 1/2 bath to 3/4 bath home improvement | wilsonkori | General Discussion | 1 | 11-11-2008 11:58 AM |
