Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 03-07-2007, 01:44 PM   #1
JamesNLA's Avatar
Trade: Plumbing & Electrical
Attic location
Gotta question for yaz!
Relocating a new FAU to the attic. Plenty of combustable inlet and all looks good! Was wondering about the insulation. No R-30 to speak of however the entire (single story-residential) attic has blown insulation.
Is there a code set requirement for the FAU's height or distance away from, above the blown?
If so, can't we just install more ply atop the CJ's?
Thx
JamesNLA is offline   Reply With Quote
Old 03-07-2007, 05:32 PM   #2
mdshunk's Avatar
I've been paging through the code, and can't seem to find anything.
I can tell you what I normally see:
  • FHU/AHU suspended from chain, and ductwork hung with strapping.
  • Platform framed with (2)2x6" set "tall ways" perpendicular on top of the ceiling joists/bottom chord and plywood put on top. This at least gives the capability to add more insulation if desired later.
Not sure what brand you're going with, but I stuck in a Trane gas unit last season in an attic that had a detail on that part in the installer booklet.
mdshunk is offline   Reply With Quote
Old 03-07-2007, 09:19 PM   #3
Mike.GCOC's Avatar
You don't mention whether this FAU will have A/C along with the furnace, but if it does then you'll need (at least in Calif.) to install a secondary drain pan under the coil. If not then just check the clearances to combustible surfaces in the specs. Most units require some clearance away from wood surfaces. I've seen some installs where they place sheet metal on the blocking where it sets to handle this.
Mike.GCOC is offline   Reply With Quote
Frost inside the attic? SOSSW Roofing 22 04-03-2009 07:26 AM
using attic to heat your water? rhinoguy Plumbing 8 02-25-2007 08:04 PM
Helping in friend's attic mess Terrence Carpentry 18 11-04-2006 01:36 PM
Seperate Location VS Home Office realpurty2 General Discussion 20 05-10-2006 05:10 AM
Location Location Location Tom R Off Topic (Non Trade) 3 11-06-2005 10:50 PM
