Armstrong HSI Board
Old 01-31-2004, 06:15 AM   #1
Bjd's Avatar
Question
Armstrong HSI Board
Morning Guys
Hey how in the hec do the people at Armstrong get 208 (3 ph) to drop down to 115 vt for the hsi igniter. The inducer motor is 208 and the systems transformer is a 208 to 24vt.
Problem is I do not have the board, some one took it some time ago as it being a roof top unit they also took all of the diagrams as well as all of the ser and mod numbers with them. Just a simple way of saying they are the only ones that can fix the unit, nice huh.
What I ended up doing is going with a Honeywell S 86 ignition system and using interminet type design. Also had to put new relay in for the inducer motor to start and stop.
But how do they make the drop down?
Bernie
Bjd is offline
Old 02-26-2004, 02:39 AM   #2
drpsr69
Guest
drpsr69's Avatar
Posts: n/a
Re: Armstrong HSI Board
They either do it with a transformer or any leg to groud is 115 volts.
Foam Board vs. OSB JimmyZimmier Framing 17 11-06-2010 05:54 PM
Licensed & Insured bjg5240 Business 34 06-09-2009 07:56 PM
Transitioning drywall with cement board Lone Wrencher Drywall 19 03-02-2008 07:05 AM
Wall Board Question, for wet areas tzzzz216 Construction 10 02-28-2006 10:39 PM
