Any Way To Safely Vent A Water Heater Without A Chimney?
Old 09-12-2017, 08:02 PM   #1
The Remodeler
Splinter's Avatar
Trade: Home Remodeler
Rewards Points: 236
I have an almost new atmospheric vented water heater I want to use in my shop but dont have a chimney on the building.
It's a 40 gal gas fired unit that I would like to stick upstairs. The concern is what type of vent material can I use, and how long does an atmospheric vent have to be for a water heater to get the proper draft? I would have about 2' of vent to the underside of the roof, just off-center of the peak.
I read bad things about using a power vent out the side wall... Would this still be the best option?
Is there an inexpensive wall mount unit I should buy instead that could vent out the wall?
Any input is appreciated... Except from Leo... He's just a smartass.
Splinter is offline
Old 09-12-2017, 08:37 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 344
Re: Any Way To Safely Vent A Water Heater Without A Chimney?
B vent through the roof is pretty standard here.
Delta
I have an Edifice Complex.
The Following 3 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
flashheatingand (09-13-2017), Splinter (09-13-2017), Tom M (09-15-2017)
Old 09-13-2017, 07:45 PM   #3
The Remodeler
Splinter's Avatar
Rewards Points: 236
So a B vent from the top of the water heater through the roof and above the ridge 2'.....
That's only going to be about 4' of pipe total... No issue with drafting?
Splinter is offline
Old 09-13-2017, 08:13 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,211
It'll work just fine.
I have a heater vent that elbows out through the wall about a foot up, then elbows up about another 2-3'--with 8' of gable wall above the top of that. Been meaning to do something about that for the last 30 years or so.
If you're paranoid, put in a CO detector.
Tinstaafl is offline
Old 09-14-2017, 06:01 AM   #5
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 3,778
Really? there are two things plumbers up here refuse to do. Use copper and run Type B. You want something new done its PEX and power vent.
They'll tie a replacement water heater to existing B vent but that's it.
Big Johnson is online now
Old 09-14-2017, 06:23 AM   #6
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 10,366
"atmospheric vented water heater"
^^^--- I had to google that.
SmallTownGuy is online now
Old 09-14-2017, 04:01 PM   #7
The Remodeler
Splinter's Avatar
Rewards Points: 236
I'm assuming you mean a new install gets a water heater with the fan built in to the top of the unit.
I was thinking about the power vents that are basically a remote unit. They get mounted to the house wall and single wall vent gets run from the heater to the fan unit. I hear those dont last.
Just didnt want any confusion with the factory installed power vent units.
Splinter is offline
Old 09-14-2017, 04:21 PM   #8
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 911
I think you should use drier vent. You know, that slinky stuff with a tinfoil covering? Make sure your CO sensor has batteries.
You asked for it, you got it.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 09-15-2017, 11:05 AM   #9
Trade: Builder/GC
Rewards Points: 344
You'd be surprised how many water heaters I come across that have dryer vent for the first few feet.
I can't imagine who thinks that's a good idea. I can't believe that there are that many HO's doing their own WH replacements.
Delta
Old 09-15-2017, 11:11 AM   #10
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 911
People in general are stupid. This doesn't surprise me.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 09-20-2017, 12:27 AM   #11
Controls Guy
MechanicalDVR's Avatar
Trade: Deplorable Electrician
Rewards Points: 1,189
Just use B-vent and make sure it terminates at least 2' higher than anything with in 10' of the termination.
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Horizontal vent cap for tankless water heater pzeiler Plumbing 4 05-29-2012 07:31 AM
Water Heater as Potable - Space Heater Goldentouch Plumbing 3 03-04-2012 04:49 PM
Is it ok to install an expansion tank right on top of water heater? Electric_Light Plumbing 29 10-24-2010 07:22 PM
