Any Info For OLD RADCO
Old 02-17-2009, 05:07 PM   #1
A.D. Const's Avatar
Trade: A.D. Contracting & Remodeling LLC.
Old unit manufacturer by Carrier Corporation. Obviosly needs replacement, but I can't get much info from the tag. Hope this is enough
Model # 617ana 030-A
Product # 617ANA030008AAAE
Serial # 1291H04089
This is an Air Handler with Electric Heat strip
If anyone can provide any info. on this unit would be very useful such as date manufactured and SEER rating if available. I can't find K/w info however, it states that it has "Heatpack installed" #314995-708, I hope this means something to some bryant or Carrier service person.
The condenser
Bryant: Model # 69anx03000abaa. Product # 690an030-B
Based on Model # I gather that it is a 2 1/2 ton, but I cant tell if it is a Heat pump or not. Hope anyone could help me with this one. Thanks
A.D. Const is offline
Old 02-17-2009, 11:38 PM   #2
flashheatingand's Avatar
Trade: H.v.a.c.
Re: Any Info For OLD RADCO
I can't tell you based on the numbers. You probably could call your local Carrier supply house and they might give you the info you are seeking based on the numbers. But, if I were on site, I would look through the condensor fan motor grill to see if there was a reversing valve between the compressor and the line-set (google heat pump reversing valve for a picture) no reversing valve..then it's an a/c. As for the Kw question, you want to count the number of elements in the air handler. Perhaps someone can describe how to identify the elements... count the number of ceramic isolators, divide that number in two and that will give you the number of elements. Now, remember this, it's 5 kw per element.
Example: You count six ceramic isolators, then you have three elements. three elements x 5kw makes it a 15 kw strip heat setup. I hope this wasn't too confusing.
flashheatingand is offline
Old 02-18-2009, 09:20 AM   #3
A.D. Const's Avatar
Thanks for your input, flashheatingand
Columbus, Ohio contractor. Need info. gtmstang General Discussion 5 01-19-2010 10:15 AM
Nwbie / help with pricing info? zombiepornstar General Discussion 60 03-26-2009 03:21 AM
Drain layers liscence info andrew07 Plumbing 3 11-19-2008 08:51 PM
Tray Ceiling Info Needed BreyerConstruct Carpentry 7 11-17-2008 10:28 AM
Any well or pump info on this site????? Jacey Plumbing 13 09-13-2008 10:01 AM
