Trade: HVAC
Air Handler Problem`
I am just moving into my inlaws condo, they told me the furnace went out, it turns out it is an electric/ cooling air handler from carrier this thing looks pretty old, it has two small blower motors on the side with a fan box which carries a transformer, a relay switch and two other switches one that says L1 L2, and another switch which seems to be a relay but not sure, I turned on the stat to call for heat but all that happens is the blowers kick on but now power to the coils to heat up, I did'nt have my meter with me to start troulbeshooting and the thing doesnt have a schematic, It should be easy to trouble shoot since it is similar to a 70percenter, my question is if I swap it out are the new air handlers easier to install? with minimal wiring? if they are 220VAC? I was thinking of replacing it with a goodman air handler.
| Material handler | boman47k | General Discussion | 11 | 08-12-2007 10:36 PM |
| Carrier Central Air Does Not Cool - pipes ice up = possible Air Handler Problem ? | Izya001 | HVAC | 2 | 11-20-2006 08:33 PM |
| Leak in Ruud air handler in attic | Geeteex | HVAC | 1 | 03-17-2006 08:07 PM |
| falling water in my air handler / furnace | PipeGuy | HVAC | 1 | 08-15-2005 12:18 AM |
| Air Handler A-Coil Backwards?? | Greg | HVAC | 2 | 06-06-2004 11:40 AM |
