Air Condition
My air conditioner keeps freezing over, the first time it was servised it needed a good cleaning, two weeks later it did it again and needed freion,
I just called my servise man he cant get out until tommorrow What else can be causing it to freeze over? Any help Thanks |
The Doctor is In!
Trade: HVAC owner
Re: Air Condition
Poor airflow (dirty evaporator coil) or dirty air filter. Blower motor not on correct speed or not going full speed. blower wheel packed with dirt. Insufficient return. Low refrigerant charge. If you had to have refrigerant added, good chance (as long as it was not misdiagnosed as low refrigerant instead of a plugged evaporator coil etc.) you have a leak. There is no way to tell how big the leak is unless you start needing recharged 2 or more times a summer then it is time to find the leak and fix/replace the leaking component.
| Car Enthusiast... I need opinion pls | realpurty2 | Off Topic (Non Trade) | 22 | 06-11-2007 09:04 PM |
| What's acceptable condition for backfill work ??? | Driftwood | Excavation & Site Work | 7 | 05-02-2007 09:25 AM |
| Bosch 5412L 12" Dual Bevel Sliding Compound Miter Saw in Pristine Condition... | Ted W | Contractor Swap | 5 | 01-08-2007 07:07 PM |
| Did anyone watch the Preakness? | Cole | Off Topic (Non Trade) | 14 | 06-02-2006 01:46 PM |
