AC Unit Ok To Use After Sitting?
Old 04-10-2009, 09:25 AM   #1
carlspackler
Guest
carlspackler's Avatar
Posts: n/a
Wondering about an AC unit. It was disconnected 2 years ago for construction purposes. This is for central air conditioning. I'd like to have it reconnected but I'm wondering if it is still ok to use after sitting so long unused and without coolant.
I usually don't post about my own stuff here, but thought the pros could help before I call in an AC guy.
Old 04-10-2009, 10:16 AM   #2
flashheatingand
Guest
flashheatingand's Avatar
Posts: n/a
Re: AC Unit Ok To Use After Sitting?
Generally speaking, it should be alright.
Old 04-10-2009, 10:45 AM   #3
ChrWright
Guest
ChrWright's Avatar
Posts: n/a
Did they seal the line set cx when they disconnected it?
We had one recently that sat a year before being reconnected. They evacuated it really well and it was fine.
Old 04-10-2009, 11:06 AM   #4
carlspackler
Guest
Posts: n/a
Thanks for the info. I'll give my guy a call and set up a reconnect.
Old 04-10-2009, 07:17 PM   #5
hvaclover
Guest
hvaclover's Avatar
Posts: n/a
Make sure you pull not only a deep enough vacuum but you put a oversized filter drier. if you closed the valves up but had no holding charge to displace the air in the unit the oil will be saturated with moisture.
And it will need a much longer evacuation than normal.
It is a R22 unit isn't it? If its R410a you will need to pull an evacuation and replace the drier a few times as POE oil in 410 systems absorb water and will not release it under vacuum.
Fixing Flat screen TV to bedroom unit?????? brianmvp Finish Carpentry 8 03-03-2010 12:13 PM
What size unit? MJM HVAC 32 04-07-2009 12:39 AM
Dropped leg to condenser unit. Teetorbilt HVAC 8 03-15-2009 12:27 AM
odd Goodman package unit problem airwick HVAC 3 07-17-2008 11:36 PM
New Central Air Unit for Ranch House Robie HVAC 9 03-25-2006 10:01 PM
