AC Compressor
Old 05-11-2004, 03:07 PM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Cool
AC Compressor
HI
My A/C compressor will work for days and pop a fuse. I'll put a new fuse in.
And it will again. Is my compressor Going out or what?
Old 05-12-2004, 07:22 AM   #2
The Doctor is In!
HVAC Doc's Avatar
Trade: HVAC owner
Re: AC Compressor
Have you cleaned the condenser coils? Is there any loose/burnt wiring to the contactor, capacitor(s), or compresser? What is the amp draw on the compresser at start-up and during the run cycle vs. the data plate ratings? If you haven't had the unit serviced in awhile, this sounds like a good time to have it checked as it may be a minor problem that if caught early, would keep it from being a BIG ($$$$) problem. Good luck.
HVAC Doc is offline
Old 07-07-2004, 03:06 PM   #3
Unregistered
Guest
Posts: n/a
Re: AC Compressor
Have an electrician come in and check all of your electrical connections. A loose connection will generate heat, cause excessive current draw and can cause a fuse to blow. I've seen this on old houses with knob and tube wiring as well as new houses where the circuit breaker will trip.
canadian tire compressor Mrmac204 Tools & Equipment 5 08-06-2007 12:16 AM
Hitachi air compressor Bill Tools & Equipment 2 06-11-2007 08:30 PM
Good cold weather compressor? TempestV Tools & Equipment 1 02-04-2007 12:25 AM
Air Compressor and Power Inverter Question plazaman Tools & Equipment 0 12-18-2006 11:06 PM
Compressor talk - Mike Finley Tools & Equipment 39 11-01-2006 06:29 PM
