Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 4.00 average. Display Modes
Old 02-14-2004, 04:49 PM   #1
Trade:
58mvp Faults
Hello,
My Carrier 58mvp Gas Furnace has suddenly started intermittently firing. There is plenty of gas pressure at the valve but will continue to run constantly without too much heating properties. There is a flame in each of the burners. Could someone please explain what the flame sensor does and how it functions? The error code that was diplaying at times were error code 34 (ignition proving failure) All troubleshooting remedies were used according to the manual given and were all proven good. This is an intermittent problem and works for a day or so then will not fire. Then suddenly will start but see weakness in the burner flames. Then once again it will fire and work as supposed to. Any suggestions w/out having a service call.
Thanks in advance.
Doug
dpbel is offline   Reply With Quote
Old 02-16-2004, 07:11 AM   #2
Bjd
Trade:
Try replacing the flame sensor, be sure the gas valve is opening and check the amp on the valve a few times during the time that it opens.
Sometimes a valve may stick long enough to delay the start, this can be shown in the amps. You may have to do it quite a few times in order to get it to fail.
Also shut the system down for a few hours, this will allow the valve to cool down. again try the amprobe test and see if the readings chenge.
You may be in for a gas valve, and or a board.
Bernie
Bjd is offline   Reply With Quote
Old 02-26-2004, 01:09 AM   #3
drpsr69
Guest
Trade:
Posts: n/a
There is a small rod which is in the burner flame.A gas flame has a electrical charge the flame sensor passes 3 to5 microamperes through the flame to the burner (ground). The sensor or flame rod will build up a coating on it . I can't remember the exact name for it.Remove the sensor and clean it with seelwool this removes the coating.It does not take much to make the signal drop below what it should be.Also if you watch the flame if the flame pulls off of the burner this will also cause a flame failure.
Old 02-26-2004, 01:10 AM   #4
Unregistered
Guest
Trade:
Posts: n/a
That is steelwool.
Old 02-28-2004, 05:54 PM   #5
Unregistered
Guest
Trade:
Posts: n/a
Talking a new web site for hvac chat
here is the URL for a new hvac chat site www.hvacchat.com this is an amazing web based chat site for hvac lovers. david
Carrier 58MVP Furnace Problem-Inlet Pipe Ice Izya001 HVAC 16 02-26-2005 06:26 PM
Carrier 58mvp problem. BLSousa HVAC 2 02-12-2005 10:41 PM
Carrier 58MVP questions clagrow HVAC 1 12-31-2004 05:03 PM
Carrier 58MVP Inducer Fan Noise? Doug HVAC 9 05-29-2004 02:59 PM
