4" Vent Capacity?
Old 03-30-2008, 08:59 PM   #1
4" Vent Capacity?
Could you run two 80 cfm
exhaust fans into one 4"
vent cap if they might both
be operating at the same time?
Don't want to get into any problems,
but the HO wants to limit roof
penetrations and doesn't care to
see the 6" cap if it's not necessary.
neolitic is offline
Old 03-30-2008, 09:06 PM   #2
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Re: 4" Vent Capacity?
Evening Neo,
I've run into this issue before as well. The issue I came up against was the risk of back flow from one bath to another--was always worried those cheap dampers might stick open.
If you decide to try it, I'd put the "Y" as close to the roof vent as possible.
Have you ever used the ALDES vent system for multiple baths? I've used two of them and like the system a lot. It's overkill if you're not working with three or more baths but is very quite and very low profile on the inside.
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 03-30-2008, 10:10 PM   #3
Originally Posted by ChrWright View Post
Evening Neo,
That is the plan.
It's a "while you're here" deal.
Re-do one one bath, new fan
part of the plan.
Now want a fan in the other bath
as well, but no more caps on the roof.
In all fairness it will be in the front
of the house, but it would mean @16'
of extra duct to get past the ridge.
Last edited by neolitic; 04-05-2008 at 03:14 PM. Reason: Big difference between 16" and 16 FEET
neolitic is offline
Old 03-30-2008, 10:17 PM   #4
TimelessQuality's Avatar
Trade: GC/Remodeling
How about an under-soffit outlet for the second one?
-Steve
"The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein
TimelessQuality is offline
Old 03-30-2008, 10:25 PM   #5
Funny...that's what my partner
wanted to do in the beginning,
but its continuous vent. (12" soffit)
I believe we'd just be pumping
steam into the attic.
neolitic is offline
Old 03-31-2008, 06:23 PM   #6
marchvac
marchvac's Avatar
Trade: marcotto mechanical in ontario
In Ontario the code does not permit it. What you could do is install an inline fan in the 4" close to the the outlet and then the Y branch to the fan boxes minus the motors. Then make the fan come on with the demand for either one. Some of the new inline fans with a backward incline blade are very quiet and powerful. hope this helps.
marchvac is offline
Old 03-31-2008, 06:39 PM   #7
Good thought, but I think this HO
will put up with the extra vent cap
before he will spring for the in-line
option and extra wiring,=.
neolitic is offline
Old 04-05-2008, 03:21 PM   #8
I'll try again...maybe a bored
HVAC pro out there today.
Since dryers run @180-250 cfm
on 4" vents (I think), would 2
80 cfm fans somehow create
a greater load than that?
Would an 80 cfm fan have a problem
lifting the damper on a 6" cap?
neolitic is offline
Old 02-12-2009, 09:09 AM   #9
shaneali's Avatar
Trade: hvac
Hi Marchvac,
I saw a post by you in another HVAC forum and had a question about a very similar situation to what you were dealing with re: a Lennox G43UF with red blinking and green on (i.e. limit switch issue). If you are out there, would you mind ideally sending me an email or alterntatively replying to this post? Thanks in advance.
shaneali is offline
Old 02-12-2009, 09:11 AM   #10
LRG WoodCrafting
Leo G's Avatar
In a vacuum system I know that 350 CFM can flow through a 4" duct. How this helps you, IDK. But I know that you can =flow that much in a vacuum, you should be able to flow that much in a pressure system.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 02-16-2009, 07:58 PM   #11
Miller257's Avatar
Trade: HVAC
In the resi world, when we duct (2) 80 cfm fans through the same penetrations we typically use 5"ø. Run 4" to a 4x4x5" wye. Do it right, do it once. the broan 634 is only 4" wider than the 636, you could probably make the 636 work with a 5" duct even though its listed as 3-4"ø only.
good luck.
Miller257 is offline
Old 02-16-2009, 08:25 PM   #12
Pompass Ass
bwalley's Avatar
The Trane Ductilator a 4" round duct has a velocity of 1800 FPM when 160 CFM is run through it.
I did not take into acount any friction loss as I don't know how many elbows are in the duct, this is also assuming it is smooth duct.
I don't think the fart fans will work properly at that velocity.
Going to 6" duct will drop the velocity down to 800 FPM.
I 80 CFM fart fan on a 4" duct will have a velocity of 940 FPM.
bwalley is offline
seal gable vents after ridge vent installed? tacoma5050 Roofing 26 01-18-2008 10:50 PM
No vent or wet vent ? nywoodwizard Plumbing 8 01-13-2008 11:21 PM
Ridge vent issues? apkole Roofing 4 05-08-2007 06:46 PM
Dryer vent question hanover Plumbing 12 11-15-2006 09:01 PM
Plumbing vent issue Knyte260 Plumbing 3 03-21-2006 07:24 AM
