Dr Heat
Trade: hvac
30 Yo AO Smith Boiler Pluged With Carbon
I was hoping one of you may have a trick for cleaning the carbon (soot) out of an AO Smith boiler. This is a round boiler with what looks like a car radiator on the top.
Is there a spray to remove soot? Just hoping an old school boiler man will help me out. The customer can't afford a new boiler. |
#1 stunner
Re: 30 Yo AO Smith Boiler Pluged With Carbon
carb or brake cleaner?
Trade: hvac tech
hacksaw blade very carefully. hope its a time and mat job
Dr Heat
Trade: hvac
Good call, on the hacksaw blade. spent two hours with a coat hanger still too plugged going tomorrow with an air compressor a shop vac and a hacksaw blade. What a mess I'm
This is a tm but I am not going to charge full bore .
Trade: HVAC Service Technician --RSES CM-- NATE Certifie
Fire it up get it warm.
Shut it down. Remove the burners. Use a garden sprayer filled with hot water and spray it down from the top. Granted there will be a mess but this method does give good results.
MechAcc's Carbon Monoxide Site Links |
| The Following User Says Thank You to MechAcc For This Useful Post: | Dr Heat (01-31-2009) |
HVAC Tech, NATE certified
Trade: Hvac technician. Boehmer Heating
i cleaned a few with some stuff from R.E. Micheal called "soot remover". spray it on, hose it out, works fine.
Best line from a customer "you here for the tune-up? the tank of 22 is in the shed, let me know if you need more." |
Trade: hvac
You use a shop vac you might be sorry. Soot is so fine it will pass thru a shop vac filer and out the vac's exhaust.
Soot Buster vacs are designed for that kinda mess. When I have a sooter I rent a soot buster from a local wholesaler. |
| rotten egg/sulfur smell from oil fired boiler | ApgarNJ | HVAC | 2 | 01-20-2009 06:15 PM |
| steam boiler locked out | Tom M | Plumbing | 52 | 10-10-2008 12:38 AM |
| Outdoor Wood Boiler Question | RopeaGoat | Plumbing | 12 | 11-16-2007 05:43 AM |
| Outdoor Wood Boiler Question | RopeaGoat | HVAC | 2 | 11-02-2007 08:45 PM |
| Know who your co-workers are! | mickeyco | Health & Safety | 0 | 07-16-2007 03:49 PM |
