Is 3 Stage Heat Needed?
Old 03-05-2005, 05:11 PM   #1
rakes9720's Avatar
Trade: Electrical Engineering
Question
Hello, We are looking for a new furnace to replace an 80% carrier 58GFA 84000btu. We have a 3 ton heat pump that works above 30 degrees. The house is about 3000 sq ft (counting the heated finished basement). Just wondering if a high-efficiency 2 stage furnace would work correctly with a heat pump, or if only one stage is necissary. We live in northeast Ohio where at its coldest it is about -5 degrees. I have read that a two stage furnace is much quieter and saves energy, but I am not sure if you ever need 3 stages of heat. Also, about what size (btu) would we need for our house?
Thanks for the help.
rakes9720 is offline
Tricks to sizing a heat pump Danno6102 HVAC 1 06-28-2007 06:05 PM
heat pump help!?!!! maxkd HVAC 1 11-10-2006 08:57 PM
Heat Pumps naturenut HVAC 3 01-27-2006 02:03 AM
Geothermal Heat and AC quickfix HVAC 8 01-14-2006 09:02 AM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 04:38 PM
