13 To 16 Seer Heatpump?
Old 11-19-2007, 08:40 PM   #1
offpiste's Avatar
Any know the payback time for the +$1000 difference between the 13 to 16 seer Goodman systems? Any issues with the the higher seer models?
Thanks
Off
offpiste is offline
Old 11-23-2007, 08:10 PM   #2
Electro-Mech. Contr.
MechanicalDVR's Avatar
Trade: Mechanical Contractor
Re: 13 To 16 Seer Heatpump?
Thanks
Off
In a higher seer unit don't go with Goodman, they aren't very good. I would say any other unit you choose would be better.
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 11-28-2007, 02:26 AM   #3
offpiste's Avatar
I was under the assumption that the higher HSPF number was better for the heating side of the unit. Does any MFG make a high # HSPF with a lower # seer?
Any real numbers about payback to jump to the higher # seer models I can look up?
Thanks
Off
offpiste is offline
Old 11-30-2007, 07:40 PM   #4
MechAcc's Avatar
Trade: HVAC Service Technician --RSES CM-- NATE Certifie
A $300 tax credit applies for units with HSPF 9.0 , EER 13 and SEER 15.
MechAcc is offline
Old 07-13-2009, 11:47 AM   #5
PoodleHeadMikey's Avatar
What is the problem that Goodman equipment has which other brands do not have?
PoodleHeadMikey is offline
Old 07-13-2009, 12:33 PM   #6
Cabinetmaker
skymaster's Avatar
Trade: Cabinetmaker
Send a message via AIM to skymaster
any opinions on LG units? Having home bilt in NC and theyuse that brand and 13 seer, builders stated it was 1500 bucks to up to 16 seer and he didnt think it was worth it
skymaster is offline
Old 07-14-2009, 06:58 PM   #7
hf05's Avatar
Trade: hvac tech
Do you live in Florida or Detroit????
hf05 is offline
Old 07-14-2009, 07:00 PM   #8
hf05's Avatar
Trade: hvac tech
might even be dead now. just noticed original post is almost 2 years old..wtf..
hf05 is offline
Old 07-17-2009, 08:22 PM   #9
Electric_Light's Avatar
Trade: student again
Thanks
Off
Depends on how much you use it and how much the power is.
British Columbia.. probably never. Not hot enough to use A/C much, among the cheapest power and too cold to rely on just heat pump. Here, a legally minimum efficiency A/C + high efficiency gas furnace would do.
TX, AZ, S. CA, Something to seriously consider.
Heat pumps are not a good solution in an area with a harsh winter. They're good for areas with mild winter and cost of electricity to run the heat pump is less than the cost of natural gas or if natural gas is unavailable.
Electric_Light is offline
Old 07-17-2009, 08:38 PM   #10
flashheatingand's Avatar
Trade: H.v.a.c.
You speak a lot of knowlege for a contract/negotiations guy Isn't the weather in Vancouver a lot like Seattle? Seattle is good hp weather. We visited Vancouver several times. We plan to go there for the olympics. But, I digress.
flashheatingand is offline
Old 07-17-2009, 09:42 PM   #11
Vancouver, yes... Get further north on B.C. and its COLD.
Ductless Split system A/C with Heatpump allsolutions HVAC 1 11-02-2006 06:41 PM
Heil 10 Seer VS Trane XR13 Chris.Peer HVAC 6 07-11-2006 08:55 PM
Opinions on unit and advice on SEER rating daveincincy HVAC 2 04-18-2006 01:20 AM
Building a custom home - HVAC options - could use a bit of help please! loriruthw HVAC 7 07-21-2004 11:56 PM
A/C (condenser) Bands Rating Unregistered HVAC 3 06-10-2004 08:59 PM
