12 Ton Trane Situation
Old 10-18-2005, 10:52 PM   #1
BUCKHAVEN's Avatar
Trade: painting/ general carpentry
12 TON,2 STAGE TRANE ...... RUNS FINE, CYCLES FINE FOR 2-4 DAYS THEN PUKES OUT . CONTACTOR IS IN BUT 1ST OR 2ND STAGE RELAYS ARENT ENEREGIZED ... SHUT POWER TO UNIT ,WAIT 5 MINUTES AND EVAP FAN COMES ON THEN 3 MINUTES LATER 1ST STAGE,THEN 3 MINUTES LATER 2ND STAGE FIRES AND ALL IS WELL FOR 2-5 MORE DAYS ... BOARD HAS BEEN REPLACED AND PRESSURES ARE A-0K... ANY COMMENTS???????????????PLEASE??
BUCKHAVEN is offline
Old 10-18-2005, 11:26 PM   #2
mdshunk's Avatar
Re: 12 Ton Trane Situation
I wish there were a little more diagnostics on some of these Trane RTU's. They just lock out, and there might be a 1/2 dozen things in the lockout relay circuit that could have tripped it. I've found that the current sensing relay for the compressor is in the lockout circuit on many, as well as a compressor windings thermostat. You'll really have to install "tattle tales" on each item in the lockout circuit and let 'er run for another 2-5 days and then look and see what shut her down. I'm kind of a Trane guy, myself. Maybe with the model # and I'd pull the print and puzzle on it a little more.
(does this unit have an economizer? Could the enthalpy controls be poorly set?)
mdshunk is offline
Old 10-19-2005, 12:05 AM   #3
BUCKHAVEN's Avatar
Will Grab Mdl # Tomorrow And Exact Specs....thanks, Thanks
anyone else in this situation? sean26 Painting & Finish Work 4 06-05-2007 08:28 PM
trane thermostat question NCSteve HVAC 11 02-06-2007 11:33 PM
Heil 10 Seer VS Trane XR13 Chris.Peer HVAC 6 07-11-2006 08:55 PM
In what situation can this nail be used? nailStapleBrads Construction 8 05-17-2006 08:47 AM
What's your take on this situation? jockmo General Discussion 16 01-20-2006 08:10 AM
