How To Get On A Building?
Old 10-05-2008, 04:28 PM   #1
grizl
grizl's Avatar
Trade: carpenter
okay, with the union watching our every move (literally) we need to be Squeaky Clean. Can I get on to a roof by using a scissors lift to the top and Hopping on to the roof from there? it's about 26 ft to the roof.
grizl is offline
Old 10-05-2008, 05:17 PM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: How To Get On A Building?
Where is your OSHA book you should have in your possession at all times?
Chris
Chris Johnson is online now
Old 10-05-2008, 05:18 PM   #3
LocalSoljah's Avatar
Trade: Plastering & Drywall
I guess that depends, some companies have safety policies that exceeds osha standards. So you may need to see what the policies are for your particular jobsite.
With that said if you are looking to make sure the union doesnt throw red flags on you, I would recommend the use of a fall protection harness tied off to the lift before you go onto the roof. If their is a parapet wall that is waist high you could safely unclip yourself once on the roof. If not you could set up a safety anchor on the roof and clip yourself to that.
LocalSoljah is offline
Old 10-05-2008, 05:23 PM   #4
JonM's Avatar
He might need some "depends" if he misses...
JonM is offline
Old 10-05-2008, 07:21 PM   #5
grizl
grizl's Avatar
Trade: carpenter
Thanks, yeah it was the "rope to lift" step i wasn't thinking of. Usually you can just step onto the roof. Our company and the general's rules do not exceed osha in this instance, but i'll tie off anyways to c.m.a!
grizl is offline
Old 10-06-2008, 01:38 AM   #6
nap's Avatar
Trade: sparky
ever consider a ladder? cheap, easy and legal (with no harness).
Tie off or barrier guards on the roof.
actually, your post is lacking in details.
why has getting onto the roof become such a difficult adventure?
nap is offline
Old 10-06-2008, 06:55 AM   #7
grizl
grizl's Avatar
Trade: carpenter
I don't have an extension ladder on the job, but I do have a scissors lift. Usually if I need to get on the roof, we just go up on the lift on cross over on the roof. Now that we have 25 union guys Yelling,chanting at us and watching our ever move with cameras, I want to make absolute certain I don't do anything illegal.
grizl is offline
Old 11-08-2008, 10:58 PM   #8
pritch's Avatar
Trade: superintendent
The thing about a scissor lift, it only takes like fifty pounds of lateral force to pust them over at height (sideways, of course). You can't climb out of one with out exerting more than that. And, according to osha, you do not need to be tied off in a scissor lift unless it has factory provided tie off points. All the newer ones do have these. And since, if it has a factory tie-off point, you must be tied off. That means you can't really get out of the thing without untieing. At least that's the opinion of our saftey guy.
I agree with the ladder. As long as it extends a minimum of 3' past the roof and is tied off, I doubt if anyone would say anything about it. It is certainly cool with osha.
There's only enough money in this job for 1 guy to be goofing off. And that's me!
pritch is offline
Old 11-09-2008, 03:31 AM   #9
Fentoozler
Celtic's Avatar
You're safety man may need to look at some newer products:
A double lanyard allows for 100% tie off ~ even when climbing.
One hook where you are at, clip to where you want to be, unhook the first one.
Too short?
Use a retractable:
You can clip it inside the lift then your harness [where a double is already] get where you need to be, attach one leg of the double, unclip the retractable ~ but clip it close by - you're gonna need it to get back where you came from!
Even with all these various lanyards and techniques...climbing out of the lift over the top rail is a no-no....use the "door" - that's why it's there...and will also help to minimize tipover when exiting at heights.
Check out Miller Fall Protection for even more options
Celtic is offline
Old 11-09-2008, 03:32 AM   #10
Fentoozler
Celtic's Avatar
Union watching or not....wouldn't you want your employees to be return home in the same condition they arrived at your job site in?
Celtic is offline
Old 11-09-2008, 12:24 PM   #11
nap's Avatar
Trade: sparky
Not trying to start an argument (really I'm not).
Do you have any support for the 50 lbs lateral force statement. It sounds a bit light but I have never seen any testing on such and would like to have that info available.
as to the OSHA and tie-off if there are facilities available:
direct from OSHA.
No.
http://www.osha.gov/pls/oshaweb/owad...ONS&p_id=23874
(print the page and slip it to your safety guy)
nap is offline
Old 11-09-2008, 12:44 PM   #12
Patrick's Avatar
do you need fall protection to climb 26 feet on a ladder?
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 11-09-2008, 09:41 PM   #13
nap's Avatar
Trade: sparky
presuming you mean a portable ladder; No.
Portable ladders: fall protection is not required for employees climbing or working on portable ladders.
Neither the ladder standard (29 CFR 1926, subpart X) nor the fall protection standard (29 CFR 1926, subpart M) requires fall protection for workers while working on portable ladders.
You note that a number of general contractors in Georgia "are attempting to require personal fall arrest systems for their subcontractors working on ladders 6 feet or higher." Although the OSHA standards do not require fall protection for workers on fixed ladders below 24 feet or on portable ladders, we encourage employers to provide additional protection.
that is an excerpt from this letter of interpretation located here:
http://www.osha.gov/pls/oshaweb/owad...ONS&p_id=23870
nap is offline
Old 11-10-2008, 10:15 PM   #14
grizl
grizl's Avatar
Trade: carpenter
yeah that problem has been solved, just tie off before you exit the basket. on to new things, under the watchful eyes.
of course I don't want anyone getting hurt. We have a good record, but it never hurts to make sure your following the regs
grizl is offline
Old 11-10-2008, 10:24 PM   #15
General Contractor
Snow Man's Avatar
Trade: Construction Management
DECOSnowRemoval&IceControl
Serving Delaware County & Philadelphia Pa
610 457-9721
Snow Man is offline
Old 11-10-2008, 10:50 PM   #16
pritch's Avatar
direct from OSHA.
No.
I will check on that myself. I know that our saftey guy is fairly knowledgable about this stuff. I'll quiz him about the 50#s, too. I kinda figured that since he made a big deal out of it, it was probably true. Oh well. Err on the side of caution. My only ambulance ride so far was the result of a fall, so I'm pretty careful up there. As far as the 100% tie-off, of course! Again, I was assuming no tie off point on the roof.
pritch is offline
Old 11-10-2008, 10:52 PM   #17
Professional Instigator
rbsremodeling's Avatar
[IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]Name:  wiley80932-big.jpg
I use a setup like this to get up on buldings
rbsremodeling is offline
Old 11-10-2008, 11:11 PM   #18
mickeyco's Avatar
Trade: Squirrel Handler
Hell no, I want them dirty and good and tired from a hard days work, for which I reward them with a pie of their choosing.
mickeyco is offline
Old 11-11-2008, 06:16 PM   #19
nap's Avatar
Trade: sparky
I linked you the letter from OSHA that clarifies the subject. Not much else I can do to prove to you that OSHA does not require what they say they do not require.
nap is offline
Old 11-11-2008, 06:23 PM   #20
Forry's Avatar
Trade: General Contractor, Remodeler
These guys do it, why can't you?
now i am scared for my future
i've got all ten
smashed a lot of them stupidly before
-john5mt
Forry is offline
Joasis (and others) how much would this building cost in your area? Mike Finley Construction 8 09-15-2008 03:51 PM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 04:46 AM
Certified Green Building Professional Training CatAlii Green Building 6 05-11-2008 04:20 PM
Nobody Wants to bid Deutsche Bank Building Now Wolf Demolition 2 08-26-2007 03:37 PM
