Fingernails
Old 02-02-2018, 07:28 PM   #1
Tom M's Avatar
Rewards Points: 6,606
Fingernails
Back September I was spray foaming a window install and the can ran out at a bad time. So without my Normal latex gloves I sprayed acetone on the parts and swapped cans.
I ended up dried foam and then chemical that damaged my fingernail. I though it would come off and be the end of it but......no.
I put on some kind of clear polish to protect it while new one grows out but I don't see any improvement
Thoughts?
Tom M is offline
Old 02-02-2018, 08:01 PM   #2
TimNJ's Avatar
Rewards Points: 2,760
Re: Fingernails
I've had plenty of spray on my hands, but never had anything like that.
I thought nail polish remover was acetone. I would think it would be eating womans' nails away??
TimNJ is offline
Old 02-02-2018, 08:15 PM   #3
Designer/Contractor
Rio's Avatar
Rewards Points: 2,050
Re: Fingernails
I don't know about sealing it like that, you might want to check with a dermatologist. I've had nail problems, lost one nail totally but it grew back, just took awhile.
I got a big box of stretch bandaid brand band aids, so much better than generic ones and would band aid up in the morning. Eventually enough of the nail had come back that many times I'd forego the band aid.
Rio is online now
Old 02-02-2018, 08:31 PM   #4
Tom M's Avatar
Re: Fingernails
I tried this and it protects but no improvement.
https://www.sallyhansen.com/us/nail-...n-miracle-cure
Tom M is offline
Old 02-02-2018, 10:21 PM   #5
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 817
Re: Fingernails
Just chop off the hand are grow a new one
Sound weird. The nail should grow back unless somehow you killed the cuticle.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 02-02-2018, 10:46 PM   #6
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 1,808
Re: Fingernails
I double checked with my wife (Chemical Engineer) and there is nothing in acetone that would/should cause a nail to come off. That leaves whatever other chemicals you were into??
Could it have been impacted? My toe nail fell off once yet I never felt pain, it just rubbed on my shoes wrong, and a couple weeks later it came off.
Are you talking the small foam cans that screw onto a gun? Like this?
Peter_C is offline
Old 02-02-2018, 11:10 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,219
Re: Fingernails
December 1st, I pulled an idiot move and mashed my thumb in the hinge side of a door. Here's what it looks like today. I figure most of a year before it stops drawing attention.
Tinstaafl is offline
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
concretemasonry (02-03-2018), hdavis (02-09-2018)
Old 02-02-2018, 11:43 PM   #8
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 817
Re: Fingernails
That hurts to look at
Carpenter by day.
http://lrgwood.com
Leo G is online now
Robie (02-03-2018)
Old 02-02-2018, 11:47 PM   #9
JoshN's Avatar
Trade: Remolding
Rewards Points: 4
Re: Fingernails
I crushed one of my fingers last March and by mid May- June looked like nothing had happened. Just takes time. Watching nails grow is like watching paint dry. Slow and boring.
JoshN is offline
The Following User Says Thank You to JoshN For This Useful Post:
Rio (02-03-2018)
Old 02-03-2018, 06:08 AM   #10
General Contractor
greg24k's Avatar
Rewards Points: 7,410
Re: Fingernails
Tom, try Hard As Hoof Nail Strengthening Cream made by Onyx Professional.
Good luck
greg24k is offline
Tom M (02-03-2018)
Old 02-03-2018, 07:28 AM   #11
Tom M's Avatar
Re: Fingernails
Ya see....by now this shouldnt be a factor
@Pete C yes one of those and no. No other chemicals I cant recall any direct injury either.
Tom M is offline
Old 02-04-2018, 06:54 PM   #12
Unger.const's Avatar
Rewards Points: 2,682
Re: Fingernails
I would have drilled a little hole by the end of the day to drain it. Use to do it with a drill bit or hot needle. Now the dremel is the best choice.
Unger.const is online now
Old 02-04-2018, 07:10 PM   #13
Capra aegagrus
Tinstaafl's Avatar
Re: Fingernails
My go-to for that is a red hot paper clip. I once had one drilled by a doctor. Never again.
This one never built that kind of pressure. The damage was actually in the nail bed, between the cuticle and knuckle. Took a couple of weeks before you could even see any evidence of the injury.
Not counting the howl when it happened.
Old 02-04-2018, 09:51 PM   #14
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 817
Re: Fingernails
If you need to drill a hole in your fingernail all you need is a sharp bit and spin it with your fingers.
Carpenter by day.
http://lrgwood.com
Leo G is online now
pinwheel (02-04-2018)
Old 02-09-2018, 08:55 PM   #15
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,210
Re: Fingernails
just heat up a paper clip and melt thru
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is online now
Hard resin flooring showing fingernail scratches after polishing (video) -John- Flooring 6 09-14-2009 08:08 AM
