Trade: asbestos/demo contractor
Fall Protection- Roof
I have built up roof edge material to remove on a roof that is
300 ft long. x 50 ft wide and 30 ft high. The roof deck is concrete. Any suggestions on installing safety lines for the workers to hook onto that will not only accomplish fall protection but also work fluidly along the 300 ft edge w/o having to constantly unhook and restablishing a new anchor point. Thank you |
#2 | |
Trade: Certified Roofing Contractor
Re: Fall Protection- RoofQuote:
Being that it's 50 ft wide you can also use a safety monitoring system by itself... |
| The Following User Says Thank You to apehangeralfy For This Useful Post: | vfkearns (03-26-2009) |
President
Trade: General Contractor and Construction Manager
A horizontal wire system can be installed at the ridge or high point, then workers can hook up to it with retractables or ropes & rope grabs. There are strict limits as to how many per wire, since each one needs 5,000 lbs. You will need a safety consultant to design, but it is cheap, efficient, and most importantly, safe.
| Ballast Removal from EPDM Roof? | tekwrytr | Roofing | 26 | 06-19-2009 05:12 PM |
| Metal roof question | Burby | Roofing | 11 | 01-22-2009 01:16 PM |
| Insulating Roof and To Vent Or Not To Vent | Morning Wood | Construction | 3 | 11-03-2008 08:39 PM |
| roof venting repair | Home Serve | Roofing | 0 | 09-08-2008 09:44 PM |
| Help with Fall protection | islandreno | General Discussion | 2 | 04-30-2008 11:29 AM |
